8 Foot Caroni Finishing Mower Dissapointment......
   / 8 Foot Caroni Finishing Mower Dissapointment......
Thinking the same thing. My ZTR manual states not to wash down the deck but to use a blower to clean off debris.
Could moisture build up under the covers?
Anything is possible but as I stated above there are 1/2 inch lips welded to the deck that the covers fit over and bolted down. See picture below. Also, these are sealed bearings and sit 3 inches above the deck with the covers over them. One would have to completely sink the mower in water a foot deep to get water to the bearings and they are the sealed type.
Since I installed the new bearings and belts last weekend I have loosened the bolt type adjustment on the belts as far as it will go so I know the belts are not too tight. A mower this large should have spring loaded idler pulleys but it only has a static type adjustment. Will also sparingly add grease past the seals before I use it next time and see what happens in the long run......
   / 8 Foot Caroni Finishing Mower Dissapointment...... #42
Really, they don't have spring on the tension adjustment linkage? Totally agree that is, well wrong.
Nope, At least not on the 8 foot unit. What is odd is that the 8 foot Caroni flail mower the idler pulley is spring loaded with much smaller belts. The 8 foot finishing mower has 5 blades and two 119” belts.
91013 (A48082)
91013 (A48082)
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
