8 Foot Caroni Finishing Mower Dissapointment......
   / 8 Foot Caroni Finishing Mower Dissapointment......
Thinking the same thing. My ZTR manual states not to wash down the deck but to use a blower to clean off debris.
Could moisture build up under the covers?
Anything is possible but as I stated above there are 1/2 inch lips welded to the deck that the covers fit over and bolted down. See picture below. Also, these are sealed bearings and sit 3 inches above the deck with the covers over them. One would have to completely sink the mower in water a foot deep to get water to the bearings and they are the sealed type.
Since I installed the new bearings and belts last weekend I have loosened the bolt type adjustment on the belts as far as it will go so I know the belts are not too tight. A mower this large should have spring loaded idler pulleys but it only has a static type adjustment. Will also sparingly add grease past the seals before I use it next time and see what happens in the long run......
   / 8 Foot Caroni Finishing Mower Dissapointment...... #42
Really, they don't have spring on the tension adjustment linkage? Totally agree that is, well wrong.
Nope, At least not on the 8 foot unit. What is odd is that the 8 foot Caroni flail mower the idler pulley is spring loaded with much smaller belts. The 8 foot finishing mower has 5 blades and two 119” belts.
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
TRUCKING INFO (A50775)
Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K...
Deutz-Allis GVL Poly Corn Head (A50514)
Deutz-Allis GVL...
