Big Barn’s Retirement Farm Shop
   / Big Barn’s Retirement Farm Shop #231
I don't really "want" a hot water pressure washer but I "need" one..... :)
I never knew they existed but one sure would be nice to have. :thumbsup:
   / Big Barn’s Retirement Farm Shop #232
Re: Big Barn痴 Retirement Farm Shop
Gale, I hope you have secured possession of that mini. It mirrors my '80s Taiwanese Enco if w/o this fancy bondo and paint job. The column riser you show is a definite plus :drool: .. and is what mine lacks. :( (6" is it? :thumbsup: .. what that fine mini deserves, IMO)
Well, the vises and the rotab here haven't been in each others' way with the small one-offs I keep doing lately. Uh, if the one in your pic is 300 mi North of you and you don't buy it ... (that riser & spindle-to-table clearance ..)
Old Grind finally I get what you were talking about when you mentioned my mill has a column riser tonight when I ordered a manual based off your remark it looks like your 80's Taiwan Enco mill. Thanks for the tip.
Vertical Mill 1.5HP Manual-Jet, Enco, Grizzly, MSC, Asian | Ozark Tool Manuals & Books
My has the 7x30 table and from another source I had found states it is 1100 pounds so I think this will work for my Select Mill and for sure is better than nothing. Ozark Tool Manuals is a name I am going to have to remember if I keep hauling in old machines. Their website makes finding manuals easy I thought. I ordered two copies so I can file one and have one to get dirty in the shop. :)
WOW! this website has a lot of free stuff to download.
https://ozarktoolmanuals.com/wp-content/uploads/pdfcatalogs/Jet_1978_Catalog.pdf
On page 24 of this 1978 Jet catalog it shows that your mill is a JVM 830. In digging for a manual tonight I read there were few sources making the Taiwan machine tools and they would tweak from the same blueprint all these different names and build to the importers specs/price points. I guess Select brand selected to go with the cost to add the column riser and the 2 HP motor. Looks like the off/on switches floated around a lot too. :)
   / Big Barn’s Retirement Farm Shop #234
Gale I don’t think it’s often that someone lucks out like you did. The fact that the machines haven’t been used and abused is worth a premium right there. Plus the tooling and accessories! Good score!
You’ll be surprised at the light weight of the tarp you ordered.
What length blade does the power hack saw take?
I fell down a deep rabbit hole going to get one of saw blades.:) They were in a drawer of tooling I had not dug through yet but I will soon. The four blades that came with the deal state RE-ORDER RS1214-5 Brazil Starrett High Speed Steel REDSTRIPE Hacksaw. End to end they are 12 3/4 inches long and are several times thicker and taller than a standard hand hacksaw blade.
Amazon states:
by Starrett
Starrett RS1214-5 Redstripe Solid High Speed Steel Power Hacksaw Blade, 0.050" Thick, 14 TPI, 12" Length x 1-1/8" Width
Be the first to review this item
Price: $16.99 Free Shipping for Prime Members
New (1) from $16.99
Specifications for this item
Part Number RS1214-5
Number of Items 1
Brand Name Starrett
EAN 7891265400475
Item Thickness 0.050 inches
Material High Speed Steel
Measurement System Inch
Model Number RS1214-5
Number of Teeth 14
UNSPSC Code 27112802
Width 1-1/8 inches
Gale you’re going to be our “resource guy” for vintage machine info.
A friend gave me this Taiwan power hacksaw for a “project”. It seems to have been dropped from a truck and needed total rebuilding. I had to refab motor mounts, frame, base, and repair the vise. It uses a 17” blade.
Pay attention to which direction the cutting arm “lifts” for the return (non cutting ) stroke. Hand hacksaws should have the teeth facing forward to cut on the push stroke.
Some power hacksaws were designed to cut on the push stroke and others on the pull.
I ditched the coolant system for it and use a wax lube stick for the blade.
   / Big Barn’s Retirement Farm Shop #236
That is one heck of a power hacksaw. I will have to check out wax lube sticks since I did not know about them. I do not think my 601 lifts at all but looking at the blade is mounted it would only cut on pull back part of the stroke. Now I know I can reverse mount my saw blade to use the other end.
   / Big Barn’s Retirement Farm Shop #238
I'm quite fortunate. I can go to the neighbors and use his when ever I "need" to!
That is nice of you to pressure wash your neighbors driveway or whatever they need. :thumbsup:
   / Big Barn’s Retirement Farm Shop #239
I do wash off the cement pad after I've used the pressure washer. Does that count? There's four Hotsey's permanently mounted in the cellar with stainless pipe to different areas of the cellar. There's always one that's available.
He has a large root cellar for potatoes. There is over an acre of root cellars under a roof plus the grading porch and other out buildings.
One acre potato storage! Made my operation TRULY “small potatoes”. LOL
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
ALTO AMERICAN LINCOLN MPV-60 RIDER SWEEPER (A51406)
ALTO AMERICAN...
UNUSED ECHO...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
J BAR SD5 5' ROTARY MOWER (A51247)
J BAR SD5 5'...
