Big Barn’s Retirement Farm Shop
   / Big Barn’s Retirement Farm Shop
That broken end on the crank handle shaft of my blower was bugging me.
I decided to add an old trailer hitch ball to add weight for momentum.
Parted off the female threaded base
Welded a short length of 3/4” NC to end of handle shaft.
Locktite
Good enough.
   / Big Barn’s Retirement Farm Shop #562
Re: Big Barn痴 Retirement Farm Shop
Now it is a "Ball Crank Handle" :thumbsup:.
   / Big Barn’s Retirement Farm Shop #566
I suspect it was actually intentional so it could be easily removed for travel. Especially on the smaller rivet forges. But if you have no need to move it often, changing tools to suit your use and sense of what is right kind of goes straight to the core of blacksmithing. To my mind, at least...
You are most likely correct. I have seen pictures where the ball is actually two halves bolted together making handle removal easier.
It’s Recycle-Reuse Day.. perhaps this idea may be of use to some.
I save the plastic stops used on adjustable back lawn chairs before they go in the dumpster.
With the use of a small wooden dowel or metal rod they can be used for dispensing rolled products.
Pic of mine used for masking paper. Electrical conduit used for axles.
   / Big Barn’s Retirement Farm Shop #569
That finish? Is it a clear coating type thing? I see the can used the word "oil" and black as the color? Tell me more or other use's as that "sealed rust" look is nice.
Either way it's a very nice finish for that forge and the exact look I'd want on that old girl:thumbsup:
   / Big Barn’s Retirement Farm Shop #570
You are an endless source for DIY shop ideas! :drink:
Baker BFD80 8,000lbs Diesel Forklift (A51691)
Baker BFD80...
Komatsu WA250-5L Wheel Loader (A52384)
Komatsu WA250-5L...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53472)
2018 John Deere...
AMADAS SPC-6 LOT IDENTIFIER 240 (A53084)
AMADAS SPC-6 LOT...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
2006 Chevrolet Express 2500 Cargo Van (A51692)
2006 Chevrolet...
