Big Barn’s Retirement Farm Shop
   / Big Barn’s Retirement Farm Shop
That broken end on the crank handle shaft of my blower was bugging me.
I decided to add an old trailer hitch ball to add weight for momentum.
Parted off the female threaded base
Welded a short length of 3/4” NC to end of handle shaft.
Locktite
Good enough.
   / Big Barn’s Retirement Farm Shop #562
Re: Big Barn痴 Retirement Farm Shop
Now it is a "Ball Crank Handle" :thumbsup:.
   / Big Barn’s Retirement Farm Shop #566
I suspect it was actually intentional so it could be easily removed for travel. Especially on the smaller rivet forges. But if you have no need to move it often, changing tools to suit your use and sense of what is right kind of goes straight to the core of blacksmithing. To my mind, at least...
You are most likely correct. I have seen pictures where the ball is actually two halves bolted together making handle removal easier.
It’s Recycle-Reuse Day.. perhaps this idea may be of use to some.
I save the plastic stops used on adjustable back lawn chairs before they go in the dumpster.
With the use of a small wooden dowel or metal rod they can be used for dispensing rolled products.
Pic of mine used for masking paper. Electrical conduit used for axles.
   / Big Barn’s Retirement Farm Shop #569
That finish? Is it a clear coating type thing? I see the can used the word "oil" and black as the color? Tell me more or other use's as that "sealed rust" look is nice.
Either way it's a very nice finish for that forge and the exact look I'd want on that old girl:thumbsup:
   / Big Barn’s Retirement Farm Shop #570
You are an endless source for DIY shop ideas! :drink:
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
30in Forks and Frame Mini Skid Steer Attachment (A51691)
30in Forks and...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
UNUSED JCT QUICK ATTACH BACKHOE DIGGING ARM (A51248)
UNUSED JCT QUICK...
2024 TOFT 1550 Hydraulic Breaker (A53117)
2024 TOFT 1550...
