I can Weld, I can't weld, I can Weld, This is getting very frustrating.
   / I can Weld, I can't weld, I can Weld, This is getting very frustrating. #51
I like the Miller online table but I still wish there was a conversion chart that showed what the numbers on my 211MVP gauges meant in terms of IPM and Voltage.
:anyone:
https://www.hobartwelders.com/files/owners-manuals/O260274E_HOB.pdf
Page 12
Find IPM pretty much near mid range (50) on my welder just needs to tweak a bit with each change of voltage....
Believe Jody here has method for calculation IPM...
Welding Tips and Tricks - TIG, MIG, Stick and a pantload of other info
Probably add $500 to cost of your welder to get digital display...
Dale
   / I can Weld, I can't weld, I can Weld, This is getting very frustrating. #52
I don’t think Mark has any problems achieving the correct settings. I believe he wishes to know what the actual voltages and wire feed speeds are.
   / I can Weld, I can't weld, I can Weld, This is getting very frustrating. #53
Just wondering if you've played around more with your mig? I have almost the same welder (255c). I might have missed it if you've already answered it but what size wire are you using. I run almost exclusively .035. I find that if the wire melting before reaching the weld it's usually one of a couple things. First is the voltage vs wire speed. Wire coming out too slow could be your problem. Secondly the drive rollers could be too loose or the wrong ones for the size wire you are using. Finally try to keep the the mig cable as straight as possible. You may need a new liner. Before replacing mine if I had a moderate bend in the cable sometimes the wire would bind just enough to slow down in speed.
   / I can Weld, I can't weld, I can Weld, This is getting very frustrating. #54
Voltage on a miller is easy set at 18-20v for most welding and 180ipm. Mig on a miller and blushield gas is like a hot glue gun, very easy!
Fluxcore mig on the other hand is a real Pain, i have never been happy with the results.
   / I can Weld, I can't weld, I can Weld, This is getting very frustrating. #55
Door chart should be pretty darn close, maybe better the generic online calculator... Finds the values for my HH140 spot on...
Dale
Dale, you are right! The 'door' settings are always spot on... sometimes I tweak based on dissimilar thicknesses but I am always in the neighborhood with a good weld. The settings seem to be a bit 'hot' so I seem to get great penetration. I just have to be carful on the edges or where there isn't much mass for heat dissipation.
   / I can Weld, I can't weld, I can Weld, This is getting very frustrating. #56
I hear and understand your pain IT. I have a Miller stick welder.. I thought welding would be easy. MISTAKE!! I don't do enough welding to become proficient.
However, I have found a beautiful answer. On those few occasions when I do need welding to be done. I ask my neighbor to come over and do the welding. He HAS been certified and is a true master at welding. He will use my welder and sticks. The job turns out beautifully and is done correctly. That's all I can ask.
As payback - I go over with my M6040 - a very small tractor in his terms - and clean out his stock feeding pens.
   / I can Weld, I can't weld, I can Weld, This is getting very frustrating. #57
Welding is like Real Estate...
Real Estate is, Location, Location, location....
Welding is , Practice, Practice, practice.....
Dale
   / I can Weld, I can't weld, I can Weld, This is getting very frustrating. #58
Dale
:thumbsup: Right you are. It take's practice to put beads in right location. I need more practice because beads occasionally end up somewhere other than the joint.:duh:
I run 035 but have found that I have better results with silver colored wire over copper color. Maybe less oxidation if not used promptly. At certain times, everything in my shop is dripping wet from condensation, Not nice at all!
   / I can Weld, I can't weld, I can Weld, This is getting very frustrating. #60
Most MIG welders have chart inside door for basic (ballpark) setting per metal thickness and wire size and whether GMAW or FCAW...
Dale
Not on my Everlast. Maybe the cheapest inverter model doesn't get one.
2018 FORD TRANSIT T150 CARGO VAN (A52577)
2018 FORD TRANSIT...
2018 KUBOTA SVL95-2S SKID STEER (A51246)
2018 KUBOTA...
ROME GK-14 LOT NUMBER 131 (A53084)
ROME GK-14 LOT...
Pallet Forks for Tractor (A51573)
Pallet Forks for...
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
2021 MACDON C3812 LOT NUMBER 34 (A53084)
2021 MACDON C3812...
