How much would a good gasoline motor cost compared to a diesel?
   / How much would a good gasoline motor cost compared to a diesel?
Our Impala's max torque occurs at 5300rpm.
You’d have to have the engine with a diesel like power band. Having to re design the equipment for a higher RPM engine would take away whatever cost advantage they might have had.
   / How much would a good gasoline motor cost compared to a diesel? #32
Don't dismiss STEAM power!
   / How much would a good gasoline motor cost compared to a diesel? #33
Yes! With steam power I only need water I can collect from the downspouts and the same fuel I use for the house...FIREWOOD! The heater adjustment is how close you sit next to the firebox.
Those old steam tractors produce enormous heat. I can’t imagine having to work one of those in the summer.
   / How much would a good gasoline motor cost compared to a diesel? #35
Well, different engines that can run on biofuel in the simplest form might become popular again.
   / How much would a good gasoline motor cost compared to a diesel? #36
But it's DRY heat! lol Actually, the Radiator in my non A/C Kubota cab is inside the cab, and I figured (espcially since I HATE heat) that it would be unbearable in the summer, but it's not. On the flipside, the doors hardly get closed in the winter. Only if a wind is coming through, and then sometimes only one.
I was serious about the merits of steam. You enjoy the electricity you have, mostly by virtue of Steam.
I call those green houses on wheels. I’d never buy a cab machine without ac.
   / How much would a good gasoline motor cost compared to a diesel? #38
I have my trusty bus driver fan! lol In and out of AC on a hot day, can make you very sick! Fine, if you are staying in the cab.
2008 FORD F-350 SUPER DUTY (A58214)
2008 FORD F-350...
Toro Sand Pro (A56859)
183 (A52705)
183 (A52705)
LOT: (2) Almost Full Jugs of Komatsu Coolant, (1) Almost Full Jug of Liebherr Coolant, 1/3 Barrell (A59076)
LOT: (2) Almost...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
AEREATOR (A58214)
AEREATOR (A58214)
