My Industrial Cabin Build
   / My Industrial Cabin Build #411
Framing stopped because I am waiting for my SIPS panels to be made and delivered. Those are my exterior walls. Joists tie in the the rear SIPS panes. Tuen the rafters will be built and the roof panels will be installed. The SIPS walls sit on the exterior block and the roof sits on top of them. That is a lot of weight And I want the walls to be backfilled to make the foundation more stable and strong. I have been working with the SIPS company this week to finalize a few issues that we identified. They also had a solution for my j-bolt issue.
Thank you for explaining that. I get worried when I see a house partially framed and nothing happening. Especially with winter coming. There is a limit to how much rain the studs can take before they start to warp on you.
Why not get the OSB on the walls that are standing so you will be that much ahead? Are you going to use OBS? or plywood? or Zip System? If the walls are going to be exposed for awhile, Zip System allows you to take your time. It's also a much better material then OSB or plywood, but it also costs $20 a sheet plus tape, where OSB is $7 right now, but house wrap.
Can you frame any of the roof while waiting on the SIPS?
   / My Industrial Cabin Build #412
The standing walls are interior.
   / My Industrial Cabin Build #414
What was the remedy for your j-bolt issue?
Most of the bolts stick up 3 inches. So they said to recess the hole on the top plate 1/2 inch and also nail the two plates together afterwards. This should work for most of the bolts.
   / My Industrial Cabin Build #417
Grass came up nice. Pretty view you have.
Thanks. We were really encouraged by the success with the grass. It seems like such a silly small thing but it can be so hard to achieve and has been rather costly.
When we finished cleaning up after the storm, we still got in about a day and a half of work on the house. Sealed between the foundation walk and the slab, and put in half the sill plates. But we were working so feverishly that I didn’t shoot any video of it.
Tomorrow we should get most of the rest of the sill plates done and start working on the bottom plates for the walls. We are expecting delivery of the sips panels the week of the 18th. We are very excited. Almost overwhelmed.
   / My Industrial Cabin Build #420
I've never worked with SIP Panels, so this is really interesting to me. Did they tell you how long it would be when you ordered them? How long did they say?
Can't wait to see you installing them, that's going to be a great day!!!!
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2015 CATERPILLAR 262D SKID STEER (A51246)
2015 CATERPILLAR...
BUSH HOG 7007 LOT NUMBER 115 (A53084)
BUSH HOG 7007 LOT...
1261 (A50490)
1261 (A50490)
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A52576)
2020 CHEVROLET...
