Truck / trailer mounted crane
   / Truck / trailer mounted crane #21
for $182 delivered, I would have to go with one of these,,,
Amazon has everything,, I usually start there, it is better than Google!!
   / Truck / trailer mounted crane #22
If you just want the pivot design, they show it in this video,,, at about 57 seconds into the video
That's helpful, thanks!
I'm trying not to admit that I will be spending more money making my own, than buying one of the Chinese versions. I like making my own inventions at times, hoping I can make something better built and easier to use. If I can pull it off, with hydraulics to raise and rotate the beam, and an electric winch to hoist, it should be pretty slick. If I get time, I'll post some pics later of the crane construction, I need some advice on choosing the right cylinder, and coming up with the rotating base.
   / Truck / trailer mounted crane #25
On my homemade excavator, I used the end off of a 3/4 ton truck axle. mount the whole thing to frame, use two single acting cylinders hooked to cable for swing and it works excellent. --- Heavy, but it works.
Any chance you can share pics?
   / Truck / trailer mounted crane #27
I like building stuff. Most everything I have has been repaired or modified to suit my needs. Equipment used for lifting usually has 10x safety factor and design features the help prevent failure.
Had a neighbor, friend, farmer, machinist and talented fabricator build a nice tractor size log wagon with self loading grapple. A retirement gift to himself for his personal use. Very professional looking and functional. He used it for a year gathering quite a bit of timber. His family found him, crushed to death by a failed pivot point one evening when he didn’t come home.
I think about that a lot when I am working, building or designing equipment and enjoying this lifestyle. Whatever you do make sure you get to come home.
   / Truck / trailer mounted crane #28
Anyone have that Maxxhaul hitch crane? Will it lift a 55 gallon drum?
   / Truck / trailer mounted crane #30
This is a do it yourself copy of the retail version, has no problem with a 55 gallon drum full of water.
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
2019 BOBCAT S770 SKID STEER (A51242)
2019 BOBCAT S770...
2019 HONDA PIONEER 5 1000 UTV (A50459)
2019 HONDA PIONEER...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
