Truck / trailer mounted crane
   / Truck / trailer mounted crane #21
for $182 delivered, I would have to go with one of these,,,
Amazon has everything,, I usually start there, it is better than Google!!
   / Truck / trailer mounted crane #22
If you just want the pivot design, they show it in this video,,, at about 57 seconds into the video
That's helpful, thanks!
I'm trying not to admit that I will be spending more money making my own, than buying one of the Chinese versions. I like making my own inventions at times, hoping I can make something better built and easier to use. If I can pull it off, with hydraulics to raise and rotate the beam, and an electric winch to hoist, it should be pretty slick. If I get time, I'll post some pics later of the crane construction, I need some advice on choosing the right cylinder, and coming up with the rotating base.
   / Truck / trailer mounted crane #25
On my homemade excavator, I used the end off of a 3/4 ton truck axle. mount the whole thing to frame, use two single acting cylinders hooked to cable for swing and it works excellent. --- Heavy, but it works.
Any chance you can share pics?
   / Truck / trailer mounted crane #27
I like building stuff. Most everything I have has been repaired or modified to suit my needs. Equipment used for lifting usually has 10x safety factor and design features the help prevent failure.
Had a neighbor, friend, farmer, machinist and talented fabricator build a nice tractor size log wagon with self loading grapple. A retirement gift to himself for his personal use. Very professional looking and functional. He used it for a year gathering quite a bit of timber. His family found him, crushed to death by a failed pivot point one evening when he didn’t come home.
I think about that a lot when I am working, building or designing equipment and enjoying this lifestyle. Whatever you do make sure you get to come home.
   / Truck / trailer mounted crane #28
Anyone have that Maxxhaul hitch crane? Will it lift a 55 gallon drum?
   / Truck / trailer mounted crane #30
This is a do it yourself copy of the retail version, has no problem with a 55 gallon drum full of water.
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
Skid steer auger plate (A50322)
Skid steer auger...
2006 CHEVROLET EXPRESS SERVICE VAN (A51219)
2006 CHEVROLET...
Kraus Drive Over Fertilizer Conveyor (A50514)
Kraus Drive Over...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2016 FREIGHTLINER...
2004 GREAT DANE 53FT REEFER TRAILER (A52141)
2004 GREAT DANE...
