/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #81
Ah, Daigle, you just HAD to say that, didn't you! (We're back into the single digits again...)
Today I gave her a hug because I will miss her...NOT!!!!
I will be on a beach in South America....
Enjoy your trip, and I hope you have a beach'in time!!
KC
Finally finished reinstalling (1/8" thick UHMW lining on the inside) the snowblower chute, it's been a long project.
Also removed all of the old 12v wiring from the 2 electric switches inside the cab and rewired them (I am a fan using the 4 wire trailer connectors for easy disconnection).
Were showing a storm coming, so I might swap out the Dozer Blade for the snowblower this weekend?
KC
(next update about this project, see post #117)
20191219_161939.jpg 20191219_161807.jpg 20191219_161722.jpg 20191219_161625.jpg
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #84
Did the same -- flat-four connector that connects just under the hood. A heck of a lot easier than the factory/dealer set-up! I use a velcro strip to gently tie it to the alternator bracket when in use.
Yes much easier to connect/disconnect the 2 electric switch controls to the snowblower.
My flat four connector is inside of the cab just below the 2 switches which are mounted on a 3/16" thick piece of UHMW that I had laying around, and located it between the hand throttle and the joy stick control lever (the extension of the UHMW in front of the switches allow me to rest my palm on it).
KC
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #86
Took my sled four steps up out of the basement. I put two wheels with a piece of pipe below the track at the rear and lift the front with a jib pole I've put on my loader. Pull it up a couple of planks and ready to go sledding tomorrow.
Got any pics?
How'd you get your sled in the basement, take a wrong turn, ha...
KC
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #88
I just wrapped up this project this afternoon. Built the hydraulic system from scratch, fabricated the joystick mount and front mount to convert a JD 318 54 inch hydraulic snow plow to my GC 2400. Been planning this project for over a year and just completed the painting today. All works extremely well....very happy with the outcome.20191228_143220.jpg20191228_143227.jpg20191228_143234.jpg20191228_143241.jpg20191228_143256.jpg20191228_143305.jpg
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #89
Nicely done cap!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #90
I love my M-F (RAD industries) front-mount blower, but there are times when I sure wish I had a plow... :drool: Very nicely done!!
Cat 936 936F 938G Forks (A59213)
Cat 936 936F 938G...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
2279 (A58376)
2279 (A58376)
EZ-GO Electric Golf Cart (A57149)
EZ-GO Electric...
2006 SHOP MADE MARATHON 20KW GENERATOR TRAILER (A58216)
2006 SHOP MADE...
2002 Toyota Camry LE (A57148)
2002 Toyota Camry...
