JD 2040 Rear SCV Hydraulics
   / JD 2040 Rear SCV Hydraulics #11
Tractor data shows it came with one set of remotes. Not that it matters, having two can be handy. One remote looks to be leaking.[/QUOTE
Due to the fact I sold new JD 2040's I can assure you that they didn't come with any SCV's from factory without an extra charge. SCV's was 1 of the ordering options & new 2040 could have been ordered with a maximum of 2 sets of scv's wheter it had open or closed center hyd's. Most utility tractors sold new at dealership where I was employed during that era had ""no scv's""
   / JD 2040 Rear SCV Hydraulics #13
That's what tractor data showed. Up until the last several years no dealer was the same.. I don't doubt what you are saying.
   / JD 2040 Rear SCV Hydraulics #14
Although Tractordata has accumulated vast amount of information with most of it being correct there are a few mistakes listed on their site.
   / JD 2040 Rear SCV Hydraulics #15
They are very good at making corrections, just send them an email.
   / JD 2040 Rear SCV Hydraulics #16
Probably no factory SCV hence the Jerry Rigged dual system. If factory equipped a pair of SCV valves are siamesed together .
If the valve is not closed centre with a closed centre pump or an open centre valve with an open centre pump, the hydraulics will malfunction.
We need a picture of the pump.
If closed center the hydraulic oil from the valve should be routed into a ported transmission filter cover. Otherwise the front pump will run out of oil if a loader, log splitter or hydraulic motor is connected.
Was this a loader tractor ?
Not sure. I don't have any history on it.
   / JD 2040 Rear SCV Hydraulics #19
The two different pumps shown in jdparts for the 2040 may help.
Open center up to s/n 349999 and then closed (right hand pic) after 350000
Edit: TX Jim corrects "up to # 266749", and he stated that in an early reply as well... but the OP hasn't offered a s/n yet.
   / JD 2040 Rear SCV Hydraulics #20
beenthere
I realize you posted serial # for each parts catalog but open center hyd's for a 3 cyl powered 2040 was only offered through serial # 266749 not 349999
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
Leeboy 8500 Paver (A47477)
Leeboy 8500 Paver...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
RIGGING BOX W/ MISC SHACKLES, LIFTING CHAINS (A54757)
RIGGING BOX W/...
2007 INTERNATIONAL 4300 SBA 4X2 DUMP TRUCK (A51406)
2007 INTERNATIONAL...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2019 INTERNATIONAL...
