JD 2040 Rear SCV Hydraulics
   / JD 2040 Rear SCV Hydraulics #11
Tractor data shows it came with one set of remotes. Not that it matters, having two can be handy. One remote looks to be leaking.[/QUOTE
Due to the fact I sold new JD 2040's I can assure you that they didn't come with any SCV's from factory without an extra charge. SCV's was 1 of the ordering options & new 2040 could have been ordered with a maximum of 2 sets of scv's wheter it had open or closed center hyd's. Most utility tractors sold new at dealership where I was employed during that era had ""no scv's""
   / JD 2040 Rear SCV Hydraulics #13
That's what tractor data showed. Up until the last several years no dealer was the same.. I don't doubt what you are saying.
   / JD 2040 Rear SCV Hydraulics #14
Although Tractordata has accumulated vast amount of information with most of it being correct there are a few mistakes listed on their site.
   / JD 2040 Rear SCV Hydraulics #15
They are very good at making corrections, just send them an email.
   / JD 2040 Rear SCV Hydraulics #16
Probably no factory SCV hence the Jerry Rigged dual system. If factory equipped a pair of SCV valves are siamesed together .
If the valve is not closed centre with a closed centre pump or an open centre valve with an open centre pump, the hydraulics will malfunction.
We need a picture of the pump.
If closed center the hydraulic oil from the valve should be routed into a ported transmission filter cover. Otherwise the front pump will run out of oil if a loader, log splitter or hydraulic motor is connected.
Was this a loader tractor ?
Not sure. I don't have any history on it.
   / JD 2040 Rear SCV Hydraulics #19
The two different pumps shown in jdparts for the 2040 may help.
Open center up to s/n 349999 and then closed (right hand pic) after 350000
Edit: TX Jim corrects "up to # 266749", and he stated that in an early reply as well... but the OP hasn't offered a s/n yet.
   / JD 2040 Rear SCV Hydraulics #20
beenthere
I realize you posted serial # for each parts catalog but open center hyd's for a 3 cyl powered 2040 was only offered through serial # 266749 not 349999
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2013 BMW X5 xDrive35i AWD SUV (A53424)
2013 BMW X5...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
2020 FREIGHTLINER M2 106 BOX TRUCK (A54607)
2020 FREIGHTLINER...
