Help Idenifying Char Lynn Power Steering Valve?
   / Help Idenifying Char Lynn Power Steering Valve? #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Eaton Char Lynn 291-515-1 Hydraulic Power Steering Valve 291 515 1 | eBay
Wondering how to identify flow rating (gallons per minute) and displacement (cubic inches per revolution) of Char Lynn steering valves similar to this? They usually show a nine or ten digit number on the nameplate but I also see ordering information in the Char Lynn catalog. The catalog shows a 30 digit number identifying all the options such as flow rating and displacement.
ADR Configuration | Eaton PowerSource
What I'm looking for, I guess, is a correlation between the two types of numbers.
Thanks for any help.
   / Help Idenifying Char Lynn Power Steering Valve? #2
It is not easy to correlate 9 digit number to the 30 digit number. I have never seen a cheat sheet showing that the 109-*** is a __ series and 129*** is the __ series. Both of these numbers are examples.
Used to be that Eaton would list some of the more common 9 digit models in the data sheets for each series of stering unit. Not sure if they still do that today or not.
Do you suppose that is a marketing ploy making it difficult to identify a used product? One would think that at least a serial number would be present so that the model could be identified by the manufacturer.
Makes we wonder how a rebuilder would know part numbers to order for replacement.
Edit: Thanks for your feedback.
   / Help Idenifying Char Lynn Power Steering Valve? #4
I would give them a call, worst they can do is tell you to get lost.
I had a used valve made by Husco that came out of a forklift which I was trying to find some information on. A 10-minute phone call to them and I had all the information I needed about the valve including how to convert it to power beyond.
Aaron Z
Thanks to your feedback, I was encouraged to do some more online searching and found this:
Open Center Non Load Reaction Archives - Midwest Steering
It gives the basic specs for the nine or ten digit number. Very helpful!
Edit: This is actually the starting page for identication:
Eaton/Char-Lynn Hydraulic Steering Control Valves Archives - Midwest Steering
Aaron Z
That's interesting as I didn't know one could be converted to power beyond! Do you remember how its done? Most of the power beyond ones I've seen have the fifth port which I could definitely use for my project.
   / Help Idenifying Char Lynn Power Steering Valve? #7
npalen,
Just an FYI: Danfoss recently purchased Eaton but I am 99% certain this acquisition is so new that Eaton tech support is still a viable option.
Agree that every unit I have seen with power beyond had the fifth port.
   / Help Idenifying Char Lynn Power Steering Valve? #8
It has a 5th port with a plug in it. They said to remove the plug (3/4" ish SAE fitting) and put a 1/2" NPT steel hex plug (installed with an allen wrench) in one of the ports.
Aaron Z
2013 Godwin CD103M Towable Diesel Pump (A59228)
2013 Godwin CD103M...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
DEUTZ MARATHON...
2006 TerraGator 8104 (A56438)
2006 TerraGator...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2018 PRINOTH...
