/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #211
Built a skid plate and primed it from this person (really like his videos).#89 Do You Need A Skid Plate On Your Massey GC 1700 Sub Compact Tractor - YouTube
Tomorrow it's paint time and then on to the SCUT.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #212
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #213
I'm thinking I'm gonna mow with the massey this year, so I reinstalled the seat safety switch. It took some doing with the new seat. I had to bend the switch bracket this and that way to get the angle right, which also required me to bust out the angle grinder to cut off the corner edge off the bracket so that it would clear the what it needed to clear. After that, fine tuning...I want that switch working only when my butt is fully off the seat as opposed to when bouncing around with bumps.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #214
With the forecast looking warmer I took off my front blower and put on the fel. I put my ratchet rake on and cleaned some ditches.
Have I doomed myself? Possibly but I left my rear blade and chains on just to be sure. ;)
Be careful what you wish for...
After I took my chain off, we got a 3" snow storm, not bad but yesterdays high was 20 degrees F and this mornings low was 7 degrees F,
Oh, but it's "Springtime" and that rodent groundhog wasn't thinking about where I live.
KC
Gene, what prompted you to reinstall the seat safety switch, which is a good thing.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #216
KC, I'm thinking to use it's mmm this year, want that pto to shut off just in case I take a spill.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #217
Would be nice if I could figure out how to disable the engine kill switch while keeping the pto kill switch intact. Anybody do that?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #218
I fixed my PSI relief valve back to spec. It had faded over time from use and I was down about 200psi
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #219
gcskid20200402_172039.jpgFinally got the skid plate on-shout out to Louisiana Tractor works for the idea.
Of course it's raining now.....Will need to wait to do the clearing.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #220
View attachment 648961Finally got the skid plate on-shout out to Louisiana Tractor works for the idea.
Don't forget to protect that hydraulic filter, that will kill your tractor faster than a broken hydraulic fan...
42FT X 36FT METAL GARAGE BUILDING (A58214)
42FT X 36FT METAL...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
453 Detroit Diesel Engine (A59213)
453 Detroit Diesel...
2019 INTERNATIONAL LT625 (A58214)
2019 INTERNATIONAL...
2022 CASE TV370B SKID STEER (A52709)
2022 CASE TV370B...
