Front 2nd axle gear=have you seen worse?
   / Front 2nd axle gear=have you seen worse? #41
I have 302-304 stainless wire in .032" and 041" sizes.
   / Front 2nd axle gear=have you seen worse? #42
   / Front 2nd axle gear=have you seen worse? #43
Thanks, but now I'm more confused. I thought it was supposed to go into the threaded part of the bolt to keep the nut from backing off. Peter's picture looks like it is in the head of the bolt.
   / Front 2nd axle gear=have you seen worse? #44
What are you trying to do?
   / Front 2nd axle gear=have you seen worse? #45
No, normally a bolt going into a threaded hole will be safety wired with the outside loop going around the head in the direction to pull it tighter, that pattern can be continued through a whole series of bolts or at least 2. Studs or or fixed threaded fasteners can have the nuts safety wired, nuts designed to be safety wired will have an offset hole that does not pass thru the center of the threaded portion.
A bolt with a hole drilled thru the threaded portion is able to be safety wired but more commonly is designed to be used with a castellated nut and cotter pin.
Below is a tutorial on safety wiring;
Safety wiring methods
And here is a castellated nut
Castle Nuts | Fastenright Ltd
   / Front 2nd axle gear=have you seen worse? #46
You can also tack weld the bolts or nuts on the dump trucks we tack weld a piece of small square stock over the top of 2 bolts on the dump pistons......
   / Front 2nd axle gear=have you seen worse? #47
I had pinion bolts come loose several times and did this. Tacked a small piece of steel between 2 bolt heads. Stopped the issues in its teacks
   / Front 2nd axle gear=have you seen worse? #48
Bolts that are tightened into a threaded hole have a small hole drilled across the bolt head for the use of safety wire, to prevent the bolts from backing out.
Safety wiring is widely used in the aviation community.
   / Front 2nd axle gear=have you seen worse? #49
Oh, now I understand. :lightbulb: Thanks
   / Front 2nd axle gear=have you seen worse? #50
Yes and the untwisted loop wraps around the portion of the bolt head to place it in tension.
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A57024)
2-Row Peanut...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2013 BMW 528i (A53424)
