6075 wont move until it痴 warmed up??
   / 6075 wont move until it痴 warmed up?? #1
steve stiller
Member
Bought new 6075 tractor last year around this time It was fine until October and had dealer do first service and all fluids are good. When you start tractor it will not move even in low range and first gear. You shift it into gear with clutch or power shift and it acts like no power draw on motor even at idle. Machine may creep a 1/4 then it seems it’s not in gear. Let it idle for 5-10 minutes then it will go, but feels like it slips not fully locked up in gear and 20 or so feet power locks up and no issues. Just got it back from dealer and It’s the same way. Mahrinda had them put a lighter/winter oil in it. Still same issue as it wouldn't back off trailer until it ran for ten minutes. This was going on in October when weather was still in 60-70 degrees in western pa. Dealer also Checked something in drive/clutch as mahrindra said they had some issues and my tractor isn't affected with ser number. Thanks in advance for any help.
   / 6075 wont move until it痴 warmed up?? #2
It shouldn’t be anywhere but at the repair shop....it’s not going to fix itself. I wouldn’t have let come off the trailer if it was still doing it.
It sounds like some type of solenoid is sticking. I’m assuming it’s in the case and they haven’t fixed it because they don’t want to split the case.
Update. Pulled tractor into my repair shop. I own stiller Motorsports. So it’s sitting in 70 degrees for 14 hours, again mahrindra told dealer to replace with low temp fluid. . Fire it up and hit reverse. Nothing, tractor moved less than 1/4” then sat there. Again I’m in low range and low gear. So I cycled bucket few times and motor just purred with no load. Had 4 of my employees push on bucket and push back a few feet and it started to move on its own sluggish. So I’m waiting for dealer to call mahrindra Monday. Not a happy camper. Second mahrindra with issues.
   / 6075 wont move until it痴 warmed up?? #4
Curious what you found out?
   / 6075 wont move until it痴 warmed up?? #7
Probably no signal or no hydraulic pressure to the power shuttle clutch packs. Also see if the EHSS foot clutch valve isn’t sticky open. Maybe change the filter again.
   / 6075 wont move until it痴 warmed up?? #8
If the dealer brought it to me and it wouldn't move off the trailer....I would tell them it ain't fixed yet so chain it back up. Maybe deliver one that does work?
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
2002 Ford Thunderbird Convertible (A59231)
2002 Ford...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
24in excavator tooth bucket (A56438)
24in excavator...
