deserteagle71
Elite Member
- Joined
- Dec 30, 2017
- Messages
- 2,729
- Location
- northern Nevada
- Tractor
- John Deere 2020 diesel, Kubota M7060HDC12
J
For long time tractor owners, just purchasing a Tier4 machine, he will need to seriously adapt to doing everything at higher rpm than he is normally comfortable with. You hear horror stories of new tractors with just 100 hours, having a plugged DPF. These tractors were never operated at higher rpm, and the owners typically idle at 800rpm and work at 1200rpm. These owners never encourage a regen cycle, because they do not get the exhaust hot enough to burn out the DPF.
Well it also happens commonly in European auto diesels, where new diesel cars, just picked up from a dealer in two weeks get a plugged DPF....because the owners never got the exhaust hot enough to burn out the DPF. You get caught in London traffic, bumper to bumper every day, with your new diesel car, and your DPF will definitly be plugged after just two weeks.
So run the tractor diesel engines at high rpm, to encourage that burn out of the DPF, and that burn out process is also called the regen process.
So I wonder how it works with the new Jeep Wranglers that have come out with the 3.0 diesel engines? Max torque on those engines is at 1400 rpm and they are set up to utilize all that torque at very low rpms (the diesel is available only with the 8 speed automatic). After a day of idling around the back country, with no opportunity to run the engine hard, is the DPF going to be clogged? Or does the DEF somehow help with that?
