any toro groundsmaster fans on here?
   / any toro groundsmaster fans on here? #891
They sometimes scuff in sharp turns with the eliminator kit... though I might put one on the 325 after I rob the clutch.
   / any toro groundsmaster fans on here? #892
Xfaxman,
I’m going to look at my first 328 soon with 3800 hours on it. It has been maintained by the local toro dealer. Are there differences between the 325/322 and 328 other than the Kubota engine? I know what to look for on the older models, but have never seen a 328. During the inspection is there anything particular I should look at? Thanks for the help.
   / any toro groundsmaster fans on here? #893
No major differences that I can think of, the float latch on the lift valve was mentioned in post #885. A minor difference is the steering cylinder is mounted behind the axle. And a different air cleaner assembly.
   / any toro groundsmaster fans on here? #894
Thank you. Should be straightforward then. I did notice in the operators manual they recommend hydraulic fluid in the transaxle. Do they use a different pump then the 325/322?
   / any toro groundsmaster fans on here? #895
From looking at the parts lists, the early models are the same, later models different. You need the 5 digit model number and serial number to find out.
Is it 4WD?
   / any toro groundsmaster fans on here? #896
Yes, it has 4wd.
I know it’s been asked before, but how much were the groundsmaster when new? I know it’s around the $20k mark, but haven’t been able to find anything definitive online.
Anyone have experience with the gigantic groundsmaster batwing mowers? It takes me about 6 hours to mow all my grass with a 325d. Starting to look at a bigger mower, but hadn’t seen much about them.
   / any toro groundsmaster fans on here? #897
I don't know how to find the new price. A dealer might be able to look it up.
   / any toro groundsmaster fans on here? #898
Pictures of Toro deck mods that I saved in the past, while looking at for sale ads.
Discharge guard:
Bumpers or push bars:
Extra wheel to prevent "deck dig in":
Please post any deck mods you have.
   / any toro groundsmaster fans on here? #899
Had some top soil to spread. Needless to say I did not spin the blades!
   / any toro groundsmaster fans on here? #900
Yes, it has 4wd.
From what I understand, a 1998 4wd power unit with Guardian Recycler deck sold for between $24-26k. Obviously deck options will change the price.
In order from least to most expensive:
Least #1- 72" side discharge
#2- 72" rear discharge
#3- 72" Guardian Recycler (mulching deck)
#4- 60" flail deck
Note: if purchased with a new unit, the 72" rear discharge included a discharge guard (similar to a skid plate) which mounted beneath the front of the traction unit and kept clippings from piling up around the axle and driveline. If you bought it afterward, the plate was a separate purchase.
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Great Dane Van Trailer (A56436)
Great Dane Van...
2017 Ford E-450 Passenger Bus (A56858)
2017 Ford E-450...
DEL MORINO VICTOR FLAIL MULTCHING MOWER (A58216)
DEL MORINO VICTOR...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
