WoodChuckDad
Elite Member
- Joined
- Jul 15, 2015
- Messages
- 2,892
- Location
- Free Union, VA
- Tractor
- Kioti RX7320 Power Shuttle Cab, Komatsu PC130-6
Eddie, this is one of those situations I was talking about, where a pro would have noticed something that I didn’t. 6x6 posts were the original plan, exactly as you described. A much easier build for the sips panels and for the post and beam.
The reenforced concrete didn’t get put in. There should have been a pillar or deeper concrete section where each post is supposed to go. I allowed for it when laying out the pex tubing but I knew nothing about cement and foundations. There were specified reenforced sections under load bearing and sheer walls and those were there, but not under the posts.
It came up in conversation with my architect when we were making a couple small changes to the plans. and I said there wasn’t any. He called the cement guy who said there was. I pulled up my photos and there are none. So the solution was bear on the filled block. Its more hassle? More expensive, more complicated. More work. But it was the solution. So onward thru the fog and fray. The next time I have cement work or anything else done by someone else I will pour over every detail and be certain it is done according to the plan.
