Carpentry,, Questions,,, and Answers,,!
   / Carpentry,, Questions,,, and Answers,,! #11
I use EBCO steel saw horses. You can put wood on the top, holds lots of weight and folds up.....but watch the pinching of the fingers. They go on sale for around $11 every year at any of the big box stores.
Model SS-29
   / Carpentry,, Questions,,, and Answers,,! #12
I'd love to have your horses! My wife is always working on projects (usually painting). Might be boards, might be shutters, might be dead bodies for all I know..... Many times, we have taken two saw horses, set them maybe 10 feet apart, put two boards across them and use THAT as a 10' wide saw horse so she can lay things out as she wants.
I have 8 sets of 10' long saw horses.
Two sets of legs, and a 10' x 1" top board (on edge)
The slip together, and knock down for storage.
They are perfect for painting projects.
   / Carpentry,, Questions,,, and Answers,,! #13
   / Carpentry,, Questions,,, and Answers,,! #14
   / Carpentry,, Questions,,, and Answers,,! #15
Note that in the photo they show a left handed person using it.
That is the strange part. I was just completing a project with my son, we are both right handed. We had to rip / cut a bunch of plywood. He had his saw out, ready to go.... but, it was the typical right sided blade.
I told him I would be right back and got my left bladed saw. After he used it on a couple cuts, he was amazed by how much easier it was to cut on the line! He said the other normal saw was “ stupid “ , he said it was much more difficult to use. He said it would be perfect for left handed people (makes sense). He got a left bladed saw the next week.
   / Carpentry,, Questions,,, and Answers,,! #16
For me, I have both plastic folding sawhorses that I like to take to jobs. I have an 8 foot bed on my truck, and space is always limited, so being able to fold and allow me to stack other stuff on them is more important then size.
The main reason that I use saw horses is for ripping plywood when I don't want to get my table saw out, or bring it to a job. the only other time that I use saw horses is to create a work table or platform. I recently refinished a 90 year old table and I set my extension ladder on the saw horses, and then clamped a 2x8 to the ladder with some screws so I could stand the legs of the table into each screw. I also put the table on the ladder so it was at an easy to work height.
When ripping plywood, I set my blade so it's just below the thickness of the plywood and then I cut right through the top of the saw horse. My folding plastic saw horses last a couple of years, then I get new ones. I also have wood saw horses that I built from scrap that are 3 feet wide and about 3 feet tall. They are more heavy duty and take up more space in my truck, so they usually only get used at home.
For cutting lumber, my chop saw is my first choice, but on a lot of jobs, I don't want to haul it around with me. Especially if I'm cutting just a few 2x's. Chop saw is for trim work, or bigger projects when I'm using it a lot. For that, I put it on my tailgate and use rollers on either side to support the material. The rollers extend up and down so it doesn't matter where I'm parked, I can quickly adjust them to the height of my chop saw, or the height of my tailgate if I'm using my cordless saw. I use my rollers a lot more then I use my saw horses.
   / Carpentry,, Questions,,, and Answers,,! #17
We usually made donkeys (saw horses) using three studs cut in half...two of them make 4 legs the other two pieces get nailed together like a "T" for the top...the leg angle is automatic when nailed to the "T"... scrap plywood gussets on the ends...lower cross pieces can be added for a step if the donkeys are being used to hold a walk plank etc...
Hate the plastic horses because they push over too easy...especially when you try to slide a stick of lumber across the top...
A handy saw hanger can be made by simply driving a common framing nail on one of the legs leaving about 3/8"... hang a circular saw by top edge of the guard on the head of the nail...
   / Carpentry,, Questions,,, and Answers,,! #18
If you use your trailer as a platform to cut a sheet of plywood on, be sure you don't saw into the fender. Those thin curf carbide blades will slice right into them. A friend told me.... So any saw horse is better then no saw horse.
Right,, "A friend told me." ,,
Is that like,, "a little bird told me" ,, or " Don't ask me how I know!! ",,
Now , you gotta show us pics of your trailer,, so we can see that the fenders are intact,, ... :rolleyes:
:eek:
:confused2:
:laughing::D:thumbsup:
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2019 KOMATSU D65WX-18 CRAWLER DOZER (A60429)
2019 KOMATSU...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
Cushman Cart (A59231)
