Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower?
   / Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower?
This tractor does not have draft controls. Next time I mow, I will get a more current picture of the setting. This was my first mowing and it was level when the mower was behind. I did adjust a good bit of that out. If you think about it, the fact that I have the angle cylinder in float it should not matter much.
The only thing that I see is the degree of angle would change with arms. This might cause a desirable effect if I needed more angle down. If I was needing a perfect 90 degree up then it would be a problem. Am I wrong?
   / Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower? #22
Been looking at getting a ditch bank flail, I've been looking at Bestco, Titan and Victory. Victory is the lowest price but I like the Bestco a little better from the pictures.
Does the pto shaft on the Victory have a cvt joint on the pto shaft at the mower?
No it is standard u joint.
   / Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower? #24
Thanks, thats what all the ones I've looked at appear to be. Doesn't matter right now anyway, all three are out of stock.
I was looking closely at the Nova Tractor units. Was about to buy theirs but understood the Victory to work with Quick Hitches. Might give them a look.
Nova Tractor Ditch mower series
   / Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower? #26
Those don't look too bad, couple things I'm not a fan of but seem to spec out decent.
Wish it didn't have the green yellow color scheme though.
Lol yes, Victory is the same color.
   / Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower? #28
I got mine from Bestco a few days ago. The shaft has a shear bolt set up at the mower. mower.jpg
   / Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower? #29
I got mine from Bestco a few days ago. The shaft has a shear bolt set up at the mower. View attachment 666922
How do you like it so far? What size did you get?
Most of the higher end versions have a cvt at the mower end due to the extreme angles it goes to. Pto shafts with cvt's are expensive so I figured the cheap models didn't have one.
   / Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower? #30
Victory told me they are out of stock until November. I got a Bestco. Haven't used it yet since my tractor is down. Seems well built can't wait to use it.
UNUSED RAYTREE RMBD72S-72' DRUM MULCHER (A51248)
UNUSED RAYTREE...
UNUSED WOLVERINE 66" BOLT ON PALLET FORKS (A51248)
UNUSED WOLVERINE...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
2001 Chevrolet Suburban (A51694)
2001 Chevrolet...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
