K5lwq
Elite Member
- Joined
- Aug 6, 2017
- Messages
- 4,818
- Location
- Mineola, TX
- Tractor
- Kioti LK2554, Branson 4815C, Satoh Beaver, Speedex
Hows the mower holding up? I recently upgraded to a used Kubota L3240, and since I need to get a larger mower anyways I figured I'd revisit the bank mowers.
I'm thinking the L should be able to handle the 64" weigjt wise, but am I going to be hating life with only 25hp at the PTO?
I don't usually cut heavy tall grass, but I do occasionally clear some underbrush in wooded areas.
Right now its looking between the titan and the Betstco, Victory has been showing out of stock for a while now and I still can't get over that color scheme!![]()
So far it is holding up just fine. I keep everything greased and clean it pretty often.
I have to keep an eye on the roller when in taller grass. The grass tends to wrap around the bearings of the roller. I have not come up with a good mod to correct that issue, yet.
I mow 90% of the time with it fully shifted to the side like if you were cutting hay. It gives the best finish in that position as the tractor tires don't mash the grass down. I also like not having to turn all the way around to see how things are going. I can just look out the side window. At first I was concerned that this would put to much stress on the mower but it really seems to be happy.
As for the color, it does not bother me at all. I have never cared about looks. I am all about functionality. Every vehicle I have bought over the years they always ask what color do I want and I also say I don't care. My wife is the opposite. Lol
In tall grass it will load my tractor pretty good unless I drop a gear. 25hp might be a little low for this size mower. I have been meaning to see how my Kioti handles it but just haven't done that yet. I turned the fuel up on the Kioti and am probably close to that 25hp mark at the PTO.
Hope this helps and good luck!
