Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower?
   / Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower?
This tractor does not have draft controls. Next time I mow, I will get a more current picture of the setting. This was my first mowing and it was level when the mower was behind. I did adjust a good bit of that out. If you think about it, the fact that I have the angle cylinder in float it should not matter much.
The only thing that I see is the degree of angle would change with arms. This might cause a desirable effect if I needed more angle down. If I was needing a perfect 90 degree up then it would be a problem. Am I wrong?
   / Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower? #22
Been looking at getting a ditch bank flail, I've been looking at Bestco, Titan and Victory. Victory is the lowest price but I like the Bestco a little better from the pictures.
Does the pto shaft on the Victory have a cvt joint on the pto shaft at the mower?
No it is standard u joint.
   / Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower? #24
Thanks, thats what all the ones I've looked at appear to be. Doesn't matter right now anyway, all three are out of stock.
I was looking closely at the Nova Tractor units. Was about to buy theirs but understood the Victory to work with Quick Hitches. Might give them a look.
Nova Tractor Ditch mower series
   / Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower? #26
Those don't look too bad, couple things I'm not a fan of but seem to spec out decent.
Wish it didn't have the green yellow color scheme though.
Lol yes, Victory is the same color.
   / Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower? #28
I got mine from Bestco a few days ago. The shaft has a shear bolt set up at the mower. mower.jpg
   / Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower? #29
I got mine from Bestco a few days ago. The shaft has a shear bolt set up at the mower. View attachment 666922
How do you like it so far? What size did you get?
Most of the higher end versions have a cvt at the mower end due to the extreme angles it goes to. Pto shafts with cvt's are expensive so I figured the cheap models didn't have one.
   / Victory Ditch Bank Flail or Bush Hog 216 Rotary Mower? #30
Victory told me they are out of stock until November. I got a Bestco. Haven't used it yet since my tractor is down. Seems well built can't wait to use it.
8" CHANNEL IRON UP TO 25' LONG (A51247)
8" CHANNEL IRON UP...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
2015 Ford Taurus CAR (A51694)
2015 Ford Taurus...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
