This day in 1997, of my house build
   / This day in 1997, of my house build #571
That picture clearly defines the complexity of your build.
Nice work!!!
19970921 Sunday
Eddie finished installing boiler piping.
Kermit and I installed stair railing.
   / This day in 1997, of my house build #574
Awesome stairs!!!! Has the railing held up to kids swinging around it???
I had a much simpler railing on the stairs going down into our basement. I finally had to replace the end post with one that ran to the ceiling so it could handle 3 boys!!! :)
The bottom post is bolted to the side of the stairs. At the top of the stairs, the rail turns into the wall and is bolted in. The spindles are in holes in the bottom of the rails, should be nailed with a Brad but I never did. Bottom of spindles are in a countersunk hole in the step. 2 spindles per step means they are different lengths.
I’m glad Kermit (RIP) knew what he was doing.
That pic taken last night, so it has held up.
19970922 Monday
Took day off work
Started putting on kitchen cabinet doors. Bank inspector came while I was doing that. As soon as she left I stopped to do other important work. The cabinet doors didn’t all get installed till almost Christmas.
Electrical and plumbing both failed final. Don’t remember why, wasn’t anything major. Fixed them that day. Scheduled reinspection.
Installed boiler exhaust pipe to the side shot power exhaust. Simple up and over.
   / This day in 1997, of my house build #578
Great pic!!!!
I used it once. Didn’t need a key, and I watched how they started it. Lol
19970923 Tuesday
Worked
Electric and plumbing both passed final inspection
Water tested.
Basement insulator didn’t show. The insulation price included them doing the basement walls at the end of the build.
One of the baths.
House was finished with 2 baths upstairs, half downstairs, and a roughin in the basement. I added the full basement bath the next summer. Permit also had a covered deck. Added the deck the next spring, but never covered it.
Never built the fireplace and chimney above the hearth.
Put a pellet stove in it’s place. 073D86AB-F56E-4719-9B73-20D49840A3DD-6043-000007BE253EF933.JPG
Here is the hearth and header where the fireplace would go. There is also a flue brought up to the first level for a wood stove connection in the basement. Chimney would of had 2 flues.
2008 CAT D6T DOZER (A55745)
2008 CAT D6T DOZER...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2004 DRAGON 150...
2011 Ford Econoline Cargo Van (A54814)
2011 Ford...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
