Woodmizer lx25 sawmill
   / Woodmizer lx25 sawmill #1
fruitcakesa
CavendishVT
M6040 JD 450C
I am reaching out to you manual BSM l owners for feedback on this mill:
LX25 Portable Sawmill| Portable Sawmills & Wood Processing Equipment
I don't intend to do any production or for hire work. Just a few boards or timbers when I need some. I have the time and energy to do that.
I Have read most of the small sawmill related threads on TBN and other sites but have found no info from users.
Has anyone used one of these small manual mills?
   / Woodmizer lx25 sawmill #3
I'm at the same point. I am also comparing the HM122 Portable Sawmill anniversary model
   / Woodmizer lx25 sawmill #4
I'm looking at the low end Hud-Son models. They would have to forgo the funky paint job though.
I just watched both the Woodmizer and Woodland Mill videos and to my eye the Woodland mill seems to be a better value and heavier construction.
The only drawback for me is the 22" maximum log diameter on the Woodland as I have a lot of large pines that exceed that.
I will check into some other brands for more comparisons.
   / Woodmizer lx25 sawmill #6
I wouldn't want to tackle any bigger logs with that model of woodmizer...
SR
   / Woodmizer lx25 sawmill #7
Couple things to consider to get the ducks in a row, how much mill can you afford that comes with extra blades, measure the trees that you want to saw into lumber, then get a mill that saws 4" bigger, then figure out how your going to load and turn the logs.........
   / Woodmizer lx25 sawmill #8
Watching with interest.
For hobby work, does it make sense to use a chainsaw mill to take the first 2-3" off each side of a log for the few large logs we might encounter? That would reduce BSM capacity by 4-6". Kerf waste would not be a large factor and it would allow using a small mill. I realize it would be slow but I could see a small 18-20" bar saw set up for that use alone (and I have an extra saw). Much of the time wasted with a CS mill results from cutting wide boards, but the first cuts are not wide. Slabbing off the top few inches should help blade life as I assume most of the dirt and crap will in the outer slabs?
It looks like about an $800 savings in initial cost for a Woodland mill between a 22" and 26" log capacity and another jump of $1200 from 26-30".
I figured extra blades are part of the expense of mill owning, I can pick and choose my trees with mill size in mind and my M will do all the heavy lifting.
   / Woodmizer lx25 sawmill #10
I'd think a chainsaw mill is one good option if one has a 70+cc saw for taking a few slabs off on big logs, it would reduce the the need for a big BSM which would reduce the cost a lot....
2015 Chevrolet Cruze Sedan (A55853)
2015 Chevrolet...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2007 Ford Five Hundred SEL Sedan (A55853)
2007 Ford Five...
2005 Peterbilt 387 with Wet Kit (A55314)
2005 Peterbilt 387...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
