Nearly went over.
   / Nearly went over.
Burder box, they reckon about 500-600kg full of packing sand.
   / Nearly went over. #32
Right click on (removed)'s icon - open in new tab - click on ignore === problem solved as long as someone doesn't Reply With Quote
I tried that but it held his place in the thread and just censored the post and I found that equally if not more annoying.
   / Nearly went over. #33
It does hold the post position, but the post itself cannot be read, unless you click on it to read.
No click = No read,.....unless part of a "Reply With Quote".
   / Nearly went over. #34
I can accomplish the same when I see his name on the post.
   / Nearly went over. #35
Rear wheel weights or loaded tires do nothing for ballast. If that is all the weight that you have on the rear of the tractor you may cause undue wear and tear on the front axle of your tractor. The rear of the tractor will stay on the ground somewhat but the weight of the load is being held up by the front axle. If you think of it like a physics problem it is pretty simple. The weight of the bag is transferred to the front axle and it is trying to lift the rear axle. This results in the rear tires coming off the ground. You need to put enough weight behind the rear axle so that the rear axle becomes the pivot point, not the front axle. This will keep the rear tires on the ground and lightens the load on the front axle.
   / Nearly went over. #36
We do disagree on this one.
I find his posts to be somewhat challenging, and certainly unique.
I did live in South Louisiana for a few months in the early 60's.
Great folks, with their very own deep dialect language.
   / Nearly went over. #37
If that was the best he could do I’d be more sympathetic but I’m fairly certain he’s taking more energy to write like that and doing it on purpose in a poor attempt to be cute.
   / Nearly went over. #39
Incorrect.
When the tractor rear comes off the ground, the front axle is the fulcrum and both rear wheel weights and loaded tires provide some counterbalance.
However, the same rear wheel weight and/or loaded rear tire weight on the Three Point Hitch is much more effective due to leverage of weight positioned further to the rear.
   / Nearly went over.
And the front wheels are 'floating' so once the back wheels are off the ground the main body of the tractor can move/roll sideways on the pivot point on the front.
2019 HYUNDAI VC2530152-JS DRY VAN TRAILER (A54607)
2019 HYUNDAI...
2015 Chevrolet Silverado 3500HD Ambulance (A52377)
2015 Chevrolet...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
