Nearly went over.
/ Nearly went over.
Did you have anything on the rear before you picked the load up?
Only a tow hitch but tyres about 80% water for ballast, have lifted round bales and 750kg bulkers many times without the rear lifting, did not know these were heavier, they all look alike and 750kg is a standard size.
/ Nearly went over. #23
Stupid people almost always continue to do stupid things......and (removed) fits that definition!
WOW !!!!
That is unnecessarily NASTY/HARSH!
A TOTAL INSULT!
I would venture a guess that (removed)'s IQ might actually be higher than yours!
/ Nearly went over. #24
Filled tires don't do much for lifting. You need weight on the 3 point.
/ Nearly went over. #25
Yes, (removed). You could be making a good point but I've given up trying to translate. It's lost in the wind ................
I did that kind of thing years ago, like 30, when all we had out here was chat rooms and bulletin boards.
I don’t even read his posts.
Whatever he’s trying to say is lost to me.
When WHAT you’re trying to say become secondary to HOW you’re trying to say it, the reader gets lost in translating the subject material.
Sam Clemons was a brilliant man but lost a lot of his readership with his style of delivery.
/ Nearly went over. #26
They help quite a bit vs nothing but tractors need substantial rear ballast to utilize the FEL and loaded tires aren’t enough by themselves.
/ Nearly went over. #27
Thank god it turned out OK for you.I always use a ballast weight plus my loaded tires when lifting heavy loads.Good lesson learned..
/ Nearly went over. #28
Right click on (removed)'s icon - open in new tab - click on ignore === problem solved as long as someone doesn't Reply With Quote
/ Nearly went over. #29
I really try and remember to put the lap belt on, just incase I drop into something and don't want to become a cushion for the tractor. It might be because i live on sloped uneven ground.
/ Nearly went over. #30
G'day Bunyip... filling an empty counterweight/ballast-box with sand will be OK-ish but it will depend on the coarseness of the sand, which will settle over time and usage.
A few bags of mixed cement would be better and you can add a couple of upright poly tubes to carry some handled tools if you'd like. There are a number of TBN threads showing what other Members have done.
I've used bricks in mine. I'm also keeping my eye out for a used/broken 'weight machine' where I can reuse the rectangular weights to replace the bricks.
/ Nearly went over. #32
I tried that but it held his place in the thread and just censored the post and I found that equally if not more annoying.
/ Nearly went over. #33
It does hold the post position, but the post itself cannot be read, unless you click on it to read.
No click = No read,.....unless part of a "Reply With Quote".
/ Nearly went over. #34
I can accomplish the same when I see his name on the post.
/ Nearly went over. #35
Rear wheel weights or loaded tires do nothing for ballast. If that is all the weight that you have on the rear of the tractor you may cause undue wear and tear on the front axle of your tractor. The rear of the tractor will stay on the ground somewhat but the weight of the load is being held up by the front axle. If you think of it like a physics problem it is pretty simple. The weight of the bag is transferred to the front axle and it is trying to lift the rear axle. This results in the rear tires coming off the ground. You need to put enough weight behind the rear axle so that the rear axle becomes the pivot point, not the front axle. This will keep the rear tires on the ground and lightens the load on the front axle.
/ Nearly went over. #36
We do disagree on this one.
I find his posts to be somewhat challenging, and certainly unique.
I did live in South Louisiana for a few months in the early 60's.
Great folks, with their very own deep dialect language.
/ Nearly went over. #37
If that was the best he could do I’d be more sympathetic but I’m fairly certain he’s taking more energy to write like that and doing it on purpose in a poor attempt to be cute.
/ Nearly went over. #39
Incorrect.
When the tractor rear comes off the ground, the front axle is the fulcrum and both rear wheel weights and loaded tires provide some counterbalance.
However, the same rear wheel weight and/or loaded rear tire weight on the Three Point Hitch is much more effective due to leverage of weight positioned further to the rear.
/ Nearly went over.
And the front wheels are 'floating' so once the back wheels are off the ground the main body of the tractor can move/roll sideways on the pivot point on the front.
Bobcat S740 (A57148)
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
2005 Kobelco 135SR Hydraulic Excavator (A59228)
2005 Kobelco 135SR...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
2004 JOHN DEERE 160C LC EXCAVATOR (A59823)
2004 JOHN DEERE...
2020 Ram 3500 4x4 Ext. Cab Pickup Truck (A59230)
2020 Ram 3500 4x4...
