LX Series Oversized Tires
   / LX Series Oversized Tires #31
Here is quantitative data straight from the Titan Catalog, so everyone can make their own decisions on what is appropriate. R1's are not included in the table.
Hope this helps.
   / LX Series Oversized Tires #32
Anyone know about the steering limiter kit that Kubota says is required for the larger tires on the LX Series? Was at my dealer today considering standard vs oversized tires. He read from the order sheet that this kit is required/included for the larger tires. He could not tell me how much this might limit turning radius. Any info/experience? Thanks!
   / LX Series Oversized Tires #33
Kubota’s “build” tool states the limiters are required, I have not been able to locate them on my tractor and have zero steering issues.
Good luck...
Good luck...
Are you sure?
Interference nearly always manifests itself between tires and FEL attachments and/or components at full steering lock and full axle oscillation.
SDT
   / LX Series Oversized Tires #36
I see no evidence of interference on mine, and I am running the 54" HD bucket, a 60" Landpride grapple, etc.
I looked for something resembling a steering stop but don't see anything on my tractor, anyone have a pic? I have no issues with turning radius.......
thanks
   / LX Series Oversized Tires #37
thanks
On the tractor with regular-sized tires, there is a turning stop, otherwise you'd break something. The $20 is just a charge they make to adjust whatever they use internally to stop the turning radius short of interference.
I dunno... Maybe they have to offset the ram or whatever they use to stop the power steering from breaking the front end by over-steering it wiht regular tires. Just a SWAG..... No, more like a WAG. Maybe in between a WAG and a SWAG :confused3:
   / LX Series Oversized Tires #38
Our tractors have bolts that hits a steering stop on both sides of the axle that is adjusted for the tire size and spacing.
   / LX Series Oversized Tires #39
I don't see them on my 3310, pic?
   / LX Series Oversized Tires #40
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56438)
2021 Unverferth...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
Abaco Machines DVL500 Vacuum Lifter (A59230)
Abaco Machines...
CASE IH MAXXUM 115 TRACTOR (A60430)
CASE IH MAXXUM 115...
2014 MERCEDES 2500 CARGO VAN (A59904)
2014 MERCEDES 2500...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
