bigtiller
Super Member
- Joined
- Feb 1, 2006
- Messages
- 6,497
- Location
- central Iowa
- Tractor
- John Deere 2720 John Deere 3039R John Deere Z545R
Carryall won't fit, but some forks would.
Ralph
Thanks Ralph.
Ralph
With 4 gallons only, you will not be able to see the oil. It'll be just below that cylindrical inlet thing.Thanks for the advice Ralph, I guess maybe I should put 4 gallons of hydro fluid in it and check the levels.
Yes, I use a Quick-Hitch with my WC68, everything lined up perfectly.Can you use a QH with this bigger unit? On the WC46, the Cat. 1 pins just stick out and aren't enclosed like on this bigger unit. Actually, how do you get the lift arms one with the pins enclosed like that?
As far as hp goes, you'd do fine with the WC68. The 2025R kind of loafs along on the WC46 at only about 2600-2700 rpm vs. 3000 for "540". Just don't need the hp.I have a tractor with a a PTO rated at 23HP, is it worth getting the WC68 instead of the WC46? Can a PTO of 23HP handle 6" diameter logs? I will chip mostly pine, birch, spruce and fir trees with it.
