L5460 goes to max RPM & no throttle control after error 20 fuse replacement
   / L5460 goes to max RPM & no throttle control after error 20 fuse replacement #1
PPCAV8R
John Deere 1050, Kubota L5460
I have a Kubota L5460 and was working some brush when the engine died suddenly and I got an error code 20. The transmission controller fuse was blown so I replaced it and got the tractor to start, but now I have no throttle control and the engine goes to max RPM upon starting and stays there. I think the likely cause is that I took a limb hit on a wire plug somewhere underneath, but I can't seem to locate it (it's REALLY tight quarters under there!). Does anyone happen to know which connector may be involved and where it is located?
Update: Fired up the tractor and repositioned it for easier access and now on later starts I'm back to the error 20 again.
Many thanks in advance.
   / L5460 goes to max RPM & no throttle control after error 20 fuse replacement #2
The WSM says error code 20 is "Communication error between ECU and IntelliPanel".
The diagram shows 2 wires (Brown and Brown & white) between the ECU and panel.
I would start looking for a separated connector where brush may have caused damage.
In the clipped image, 9 is the ECU and 3 is the intellipanel.
Hope this helps. I have a vague recollection of a very similar topic here on tbn recently... A thorough search may find something.
Thanks a lot, I've been under there digging and haven't found anything yet. I'll try again tomorrow.
   / L5460 goes to max RPM & no throttle control after error 20 fuse replacement #4
The topic I recall included where the connector was on the tractor, and I'm pretty sure it was an L60 series with the same error code.
Definitely try searching here for the topic.
   / L5460 goes to max RPM & no throttle control after error 20 fuse replacement #5
Here's the thread I saw, but it was about the L40 series.
Worth the read...
Error 20 ?
Thanks, yep, I did search the topic and found the thread you mentioned. I was hoping to see a very specific location or photo for the connector in question, but didn't see that in the thread which is why I asked here.
Back to crawling under the tractor now LOL!
Checked 4 electrical plugs that I could see on the right side of the transmission housing and all looked good. No obvious broken wires or plugs.
Anyone know where the ECU is located on an L5460?
   / L5460 goes to max RPM & no throttle control after error 20 fuse replacement #9
Main ECU is inside the squared off plastic coming out of the floor board under the steering wheel. I can't see my own attachment.
The Engine ECU (not mentioned for error 20) is under the seat. I got confused with the two when searching.
   / L5460 goes to max RPM & no throttle control after error 20 fuse replacement #10
Deleted.
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
1995 John Deere 7400 (A60462)
1995 John Deere...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56438)
2021 Unverferth...
Deere 35P (A53317)
Deere 35P (A53317)
