How difficult to install factory Kubota rear remote kit?
   / How difficult to install factory Kubota rear remote kit? #1
tallguy104
Australia
B2301
Hi folks.
I've got a fairly new Kubota B2301 and I've just purchased the factory rear remote control valve kit:
I'm new to tractor ownership, but I'm doing my own basic servicing (oil + filter changes etc) as I've done this plenty with cars / motorbikes over the years.
I've never done anything with hydraulics except connect/disconnect my tractor attachments though. Can anyone suggest how difficult it would be for a guy like me to install some rear remotes? Fairly easy, or is this kind of job best left to the dealer?
I've found an earlier thread with a few tips on installing the same kit.
Otherwise there is nothing else I can find on the internet/YouTube about installing this kind of remote kit.
Here are the instructions that came with it:
So basically I need to pull off the fender and assemble all the bits as per the exploded diagrams, making sure I grease the O-rings and use my torque wrench where it says to.
Am I missing anything major? Am I supposed to drain all the hydraulic fluid from the tractor (or maybe depressurise it somehow at least?) before messing with hydraulics or something?
Something else I need to be aware of...?
   / How difficult to install factory Kubota rear remote kit? #3
Never did a factory kit due to cost. But gotta imagine it should go smoothly. Kist follow the instructions like Rick said. Shouldnt need any special tools or knowledge. Just a basic set of wrenches and an understand of how to use them.
Ok thanks guys. When they say to apply grease to the o-rings...is this a special kind of grease, or do I just use some of the usual grease out of my grease gun?
   / How difficult to install factory Kubota rear remote kit? #6
I dip the fitting/o-ring in whatever hydraulic oil the machine runs.
   / How difficult to install factory Kubota rear remote kit? #7
Vaseline can damage some seals. Use the hydro oil or silicone grease.
   / How difficult to install factory Kubota rear remote kit? #8
Vaseline can damage orings made from natural rubber. Orings and seals used to contain hydraulic, gear and motor oils have to be resistant to petroleum products. Vaseline, being a petroleum product, won't damage these types of seals and orings.
Vaseline has been used for decades to lube seals and o-rings during assembly. Don't use it on rubber.
Ok thanks guys.
I've got another newbie question for y'all, that I can't quite figure from the manual:
transmission oil and hydraulic oil - are these one and the same?
   / How difficult to install factory Kubota rear remote kit? #11
Ok thanks guys.
In my L4330 Owner's Manual, it refers to Transmission oil when the tractor has the HST. When it's a geared tractor (like mine) it's referred to as Hydraulic Oil. Same fluid - SUDT.
Ok great, thanks guys
   / How difficult to install factory Kubota rear remote kit? #13
I installed remotes on my L5030, wasn’t too bad.
Ok just to report back. I think I got it all installed ok. It wasn’t terribly difficult. I’m yet to give actually start the tractor, so I will let y’all know whether it indeed works shortly. The instructions are certainly a bit lacking, sometimes you had to defy them or else it logically could not be assembled. Both the instructions and the exploded diagrams leave out an entire (large) bolt which is supplied and clearly necessary. There’s a puzzling number of o-rings left over, but after scrutinizing the instructions for a forth time over I’m positive they’ve not been left out of anything.
Kubota’s tolerances are impressive, the whole thing only just squeezes in. The biggest concern I have is with the end of the bolt pictured which sticks out far enough to press against the fender. I didn’t notice as I was tightening the fender retention bolts that it was pulling it in against the bolt- enough to slightly bend the fender and knock off some paint.
I’m worried it might be putting a dangerous amount of pressure on the whole remote assembly…?
I guess if I remove the fender again I should be ok to just grind the end of that bolt off? I can’t see that I’ve put it on incorrectly
   / How difficult to install factory Kubota rear remote kit? #15
Hopefully you used all the o-rings that were needed and the ones you have left are just extras.
Start it up and use it.....pay attention to all your fittings and valves til your confident there are no leaks
   / How difficult to install factory Kubota rear remote kit? #16
An old joke is how many times do you have to rebuild a carburetor before you have enough spare parts left over to build a second carburetor. When I rebuilt the valves on a piece of equipment the kit had so many extra parts I called the dealer, he said they had no idea why there were so many extra parts in some of the rebuild kits.
Is that the bolt that goes through the entire valve body? I can't see where the head is. I'd vote for either cutting it off or putting it in the other direction if that's a possibility.
   / How difficult to install factory Kubota rear remote kit? #17
FWIW, I installed a similar kit on my old L3010 HST. The biggest problem I had was getting access to the tractor hydraulic port. I wound up taking the tire and fender off which turned out to be most of the work. The actual valve install was fairly easy.
This may be completely different with the B2301 however.
   / How difficult to install factory Kubota rear remote kit? #18
Hello folks,
I’m new here but wanted to show Tallguy my B2601 recently Dealer installed OEM rear remotes. I included some photos of my setup and the spacer that has the square notch in it looks like mine is different. The bolt on yours may not be screwed in far enough.
The nut on mine is flush with the end of the long threaded rod, and leaves a slim gap Between the fender.
The Diameter of the spacer Is .786 of a inch, and the length is 2.900 of a inch.
I hope this may help you as a reference.
I only have 10 hrs on my first and only tractor.
Only 21 more weeks until Brian from FitRite Hydraulics sends me my Top and Tilt cylinder order.
Those extra O Rings are indeed replacements as I got some in packages from the dealer when they returned the unit After the install just a couple weeks ago.
One of the valves is the B7305 which is the valve with Float detent option.
Oh wow, thanks Shish, that does definitely help. Looks like mine is no where near in far enough.
I will be removing the fender again and checking that threaded rod/bolt to make sure it is in all the way. It was hard to get a grip on it when trying to tighten it, since it just has threads on either end and no head to put a spanner on. So I will try some vice grips.
Thank you also to the others for your comments/reassurance.
bdhsfz6 you are right, most of the work is in getting to the area to fit the unit. Next time I would remove the wheel as well as the fender like you said.
   / How difficult to install factory Kubota rear remote kit? #20
Ok thanks guys.
Sure are. Hopefully, you are staying up on your maintenance. Kubota install instructions are pretty straightforward. I see they even supply latex gloves, nice touch. I did a 2 speed PTO conversion on one of my M9's and they even supplied a tube of 3 bond gasket maker for the mating flanges. Didn't get no latex gloves though...lol
Just follow the instructions step by step and you won't have any problems.
Far as removing the fender, block up the rear of the tractor securely, remove the right hand tire and rim and unbolt the fender, noting where all the rubber cushions, grommets go and have at it. I've found that when a bolt or screw is tough to remove, a bit of heat from a propane torch helps a lot. Finally, be sure to stick to their torque specs.
Kubota only uses one transmission and / or gearbox oil, SUDT. That goes in the front axle too (if your unit is front wheel assist).
Have fun, a nice weekend project.
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
2018 Chevy Silverado 1500 4X4 (A61306)
2018 Chevy...
2021 Deere 333G (A53317)
2021 Deere 333G...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
