Been busy!
Driveway and parking area for 1, shed pad for 1, large driveway resurface for 1 and a new tow buggy!
I'm not seeing the pix except for the last one.After starting the project in mid-August during a vacation, to breaking a piston which delayed 3 weeks for parts. Then having to wait till the outage was over, we finally have water and power to the animals
It's not inserting them properly, don't know why.I'm not seeing the pix except for the last one.
What size garage? How many btu's?Been a great week of vacation. Did the 500 hr service on the machine then got to work on a series of projects. I trenched a gas line to my garage to power a workshop heater for the winter before it really sets in. Then backfilled the trench once everything tested out ok. Then strapped up the chipper and whipped out my trusty Echo CS-400 and turned a crabapple tree into woodchips. The little tractor never ceases to amaze me.View attachment 722172View attachment 722173View attachment 722174View attachment 722176View attachment 722177View attachment 722178
30k BTU unit with built in fan to dispurse heat over a 480sq ft garage that isn't really greatly insulated. Unit itself is advertised for 1k sq ftWhat size garage? How many btu's?
On my time do list next year
It's all relative. What size are you trying to heat? Is it insulated at all? (I have R13 on the walls, 16' x 7' door is maybe half that that or less and poorly sealed, and silverboard R3 radiant barrier board on the ceiling.)Ahh, I'll probably need 100-125k btu and I'm looking at midline or similar.
It's 36x42 with R21 on walls and insulating the vaulted 20' ceilings in the spring so I'll need a bit more than 60k. I store the MH in there so it had to accommodate a 14' overhead door.It's all relative. What size are you trying to heat? Is it insulated at all? (I have R13 on the walls, 16' x 7' door is maybe half that that or less and poorly sealed, and silverboard R3 radiant barrier board on the ceiling.)
You can heat a modest ranch house on a 60k BTU unit
Nice building. So you're definitely in a spot here. Fully Insulated you'd need a 60k BTU furnace for that space as an everyday heat source especially if you double the r value you put on the ceiling vs the walls. Your building looks far more airtight than mine so a 60k BTU furnace will work but twice as hard/cycle twice as often due to the lack of insulated ceilings. Does the 14' door have a weather seals and insulated panels?It's 36x42 with R21 on walls and insulating the vaulted 20' ceilings in the spring so I'll need a bit more than 60k. I store the MH in there so it had to accommodate a 14' overhead door.
Pics taken last year
Son rolling after spraying
Chains certainly get easier the more you do them but it's never easy just an easier way. My rear insides were the pita for me, getting the slack out of them and locking them into place. It's even more fun at the bottom of the hill after they've come loose, lying in the snow and water dripping in your face. (Not me, a friend of mineChains are similar, if not identical to mine. I'm on a hill and can get some serious ice. There is a thread somewhere about putting on chains somewhere that makes the process quick an easy.
Mounting tire chains
I put chains on one tractor yesterday, there are lots of ways to mount chains I thought I would share the easiest way I have found to do so. 1) lay the chains out with the outside, the ground contact side facing up 2) tie a short cord to the side chains, the length will depend on your tire...www.tractorbynet.com
