/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,141
Been busy!
Driveway and parking area for 1, shed pad for 1, large driveway resurface for 1 and a new tow buggy!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,142
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,143
After starting the project in mid-August during a vacation, to breaking a piston which delayed 3 weeks for parts. Then having to wait till the outage was over, we finally have water and power to the animals
I'm not seeing the pix except for the last one.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,144
added my 1.5" spacers today
stock no spacers
1.5" spacer added
since my backing plate was in real good shape I did not want to alter it. I picked up some M12 1.5 pitch 50mm bolts and drove them thru backside with loctite on last few threads. do not use lock washer/etc here if you do this, you want the bolt head as tight against axle flange as possible. I spun them in to approx 50 ft lbs torque and let loctite cure a few minutes.
then just bolt on the adapter, I had a bunch of old lugnuts from wifes 2013 explorer which were also a 12m 1.5 pitch so that worked out well.
and then just toss tire on like normal. even if I hadn't been going with a spacer I would have done this as hanging a tire off a stud is a LOT easier then holding a tire up to a hole and inserting a lug BOLT.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,145
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,146
After starting the project in mid-August during a vacation, to breaking a piston which delayed 3 weeks for parts. Then having to wait till the refuel outage at work was over, we finally have water and power to the animals.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,147
Been a great week of vacation. Did the 500 hr service on the machine then got to work on a series of projects. I trenched a gas line to my garage to power a workshop heater for the winter before it really sets in. Then backfilled the trench once everything tested out ok. Then strapped up the chipper and whipped out my trusty Echo CS-400 and turned a crabapple tree into woodchips. The little tractor never ceases to amaze me.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,148
Been a great week of vacation. Did the 500 hr service on the machine then got to work on a series of projects. I trenched a gas line to my garage to power a workshop heater for the winter before it really sets in. Then backfilled the trench once everything tested out ok. Then strapped up the chipper and whipped out my trusty Echo CS-400 and turned a crabapple tree into woodchips. The little tractor never ceases to amaze me.View attachment 722172View attachment 722173View attachment 722174View attachment 722176View attachment 722177View attachment 722178
What size garage? How many btu's?
On my time do list next year
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,149
30k BTU unit with built in fan to dispurse heat over a 480sq ft garage that isn't really greatly insulated. Unit itself is advertised for 1k sq ft
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,150
Ahh, I'll probably need 100-125k btu and I'm looking at midline or similar.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,151
It's all relative. What size are you trying to heat? Is it insulated at all? (I have R13 on the walls, 16' x 7' door is maybe half that that or less and poorly sealed, and silverboard R3 radiant barrier board on the ceiling.)
You can heat a modest ranch house on a 60k BTU unit
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,152
It's 36x42 with R21 on walls and insulating the vaulted 20' ceilings in the spring so I'll need a bit more than 60k. I store the MH in there so it had to accommodate a 14' overhead door.
Pics taken last year
Son rolling after spraying
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,153
Nice building. So you're definitely in a spot here. Fully Insulated you'd need a 60k BTU furnace for that space as an everyday heat source especially if you double the r value you put on the ceiling vs the walls. Your building looks far more airtight than mine so a 60k BTU furnace will work but twice as hard/cycle twice as often due to the lack of insulated ceilings. Does the 14' door have a weather seals and insulated panels?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,154
I'm pm'ing so the rest of our mf friends don't have to be bothered going through all the rest. :)
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,155
yesterday I replaced the throttle cable (only 11 months old) due to it freezing :(😠
even running tractor for 40 minutes would not unfreeze it sometimes.
do visible damage to cable, suspect rain got onto cable end at throttle control and seeped into cable there.
gonna hang old cable in front of shed furnace for week or so and hopefully can save it as a spare.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,156
Dave, that issue is relatively common, with newer GC models; I've never had a freeze-up in my old 2310. Glad you could sort it out "easily"!
So-- over here, I'm getting real tired of these "roller-coaster" winters we've had over the past few years... You know, starts out as rain, temps drop, changes to wet snow, then just plain snow. Makes for an extremely greasy mess, not to mention ice that gets left behind!
So far this winter, in clearing the 4" and then the 2" of wet snow we've had (using FEL to save blower from stones from the dirt road early in the season), I've slipped --badly, accelerating BACKWARDS-- off the driveway TWICE and gone into the rather deep drop-off on the left side of the driveway.
NO FUN! Both times I had to enlist the help of one of our 4WD Subarus to pull the poor red beast back up into the pavement. Embarrassing, yes, but darned scary, going backwards down the hill while all 4 tires on the tractor are pulling forward! Last time, I fortunately remembered to drop the FEL to ****** my slipping; really thought I was about to roll the tractor over. Using the rear diff lock-up helped going up, but no help once you start sliding backward!
NO MORE! Yesterday I finally bit the bullet, removed the FEL, put that away, installed the blower, AND MOUNTED MY CHAINS ON THE REARS. I just hope the early-season piles of stones from the road plows have now been pushed away by my FEL And, of course, tomorrow it's supposed to hit the 50s with rain, after two mornings with light dustings and temps in the teens....sheesh.
These chains area PITA to install, but they sure do work -- check these babies out! (Here's where I make one of those Tim-The-Toolman growls: GRRRR!)
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,157
Those chains look pretty serious.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,158
Chains are similar, if not identical to mine. I'm on a hill and can get some serious ice. There is a thread somewhere about putting on chains somewhere that makes the process quick an easy.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,159
Chains certainly get easier the more you do them but it's never easy just an easier way. My rear insides were the pita for me, getting the slack out of them and locking them into place. It's even more fun at the bottom of the hill after they've come loose, lying in the snow and water dripping in your face. (Not me, a friend of mine😉)
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,160
so decided to look at my pedal return issue today, had already bought new pedal bushings.
disconnected rod from pedals and pedals, no matter what pressure (sideways, etc) applied in any direction, moved freely.
so the 8$ of bushings not needed.
dug into it, disconnected lot of items, everything moves pretty freely.
reconnected everything looked at return spring, it was 3/4 tightened. so wound it up full. no difference in pedal pressure, no diffeence in pedal return.
ordering new pedal return spring (part # 4265419M1 approx 18$) tomorrow. dealer will prob take back the unopened bushings and apply towards the price, they treat me pretty well as I treat them well when I go in.
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2016 VOLVO SD75B SMOOTH DRUM ROLLER (A60429)
2016 VOLVO SD75B...
(32) 8" FLOOR TRUSSES (A60432)
(32) 8" FLOOR...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
