Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures!
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #321
Higher volume is much better than pressure. Pressure drives the dirt deeper into the bark, unless you have major pressure and blow the bark off and that's something I don't like to do.
SR
Was thinking SR, about using the very low-pressure nozzle . . . :) .
I have 40 pounds of pressure coming from my garden hose which seems to work pretty well, although a bit slower than SR's firehose. I just keep flooding the log, then brush it off with a floor broom. I'm not sure what I will do this winter, but hopefully we will get enough snow so that it isn't an issue.
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #323
High volume works best, and it works really great for cleaning out the tracks on the dozer too,
SR
Is that hose system a permanent setup?
Also, I've seen that same kid washing logs off for you. Is he a permanent fixture, or just somebody you bring in for photoshots? :D
SR
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #325
My buddy would come over and bring his two grandkids. They would almost get in a fight over who gets to run the firehose! SO, not wanting a fight, I'd "let" each one clean one side of the dozer tracks. lol The hose is hooked to a "gas engine" Kubota pump.
I don't wash many logs, but one time I took a job that I needed to log some 100 plus year old pines, and mill them for the guy. They were on a ridge on the back side of a big sand pit, and there was NO WAY to get them out, but to skid them through some sand,
I pulled out load after load, and you can see how dirty they got,
Anyway, I had a guy working for me and he would bring his boy with him, that kid LOVED to wash logs!! We'd take a break while his kid got after it. lol
SR
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #326
The pointer on my log scale was annoying me. It obscures an inch and a half of the graduations when moving up and down. I noticed on some of the other woodland mills sawmills that they had a clear pointer so I made one out of Lexan for my 130 to try it. I like this way better. It was throwing me the way it was so this is a good fix.
I can see why you changed it.
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #328
But should your new measurement line be at the top of the clear plastic?
   / Sawmills, sawmill buildings, drying sheds, and kilns... show your pictures! #329
I may do that because I went to the top a few times simply because the old pointer worked that way. I caught myself before messing up a cut. I may try a bright red line right in the middle before I do that. Just messing around to see what works best for me.
2006 Crimson Spartan Fire Ladder Aerial Truck (A52377)
2006 Crimson...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
Caterpillar 262 B 4 Tires Solid with Rims (A53117)
Caterpillar 262 B...
PumpJack Brand Pump Jack (A53473)
PumpJack Brand...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
