Kubota 10W30 oil, synthetic or dino?
   / Kubota 10W30 oil, synthetic or dino? #21
Only thing the local TSC has here is 'Traveller' and I ain't buying that junk. Menards is the bomb. Too bad they dropped the 11% rebate. Understandable. Rimes are tough.
Why compare Amsoil small engine oil to T6,
Amsoil Diesel 5W-40 and Rotella T6 5W-40 would be a more valid comparison.
It wasn't just Amsoil engine oil, it was their 5W-40 ATV/UTV oil and their 10-30 4 stroke power equipment oil. Amsoil made a big deal of the additive package in both oils having "superior acid fighting and detergent packages." Upon examination, Rotella T6 5W-40 was superior in all areas, in most areas by quite a margin. Not to mention the T6 was much cheaper. Diesel oils naturally have a better acid fighting package, (TBN) and detergent package because of the inherit soot that diesel engines contaminate their oil with. You can't run the diesel oil in a gas engine with a catalytic converter or you will kill it in short order.
   / Kubota 10W30 oil, synthetic or dino? #23
Interesting comment in as much as I use T6 in every engine I own and have for years. I don't believe in purchasing different oils, never have. My wife's van has 190K on it and the cat is just peachy.
   / Kubota 10W30 oil, synthetic or dino? #24
Gonna bow out of this thread. I really don't like any oil threads, all go down the same rat hole. Have a good dau...
I'm just repeating what it said in the email from Shell Oil when I asked them about using in in gas engines with catalytic converters. If it works for you, great. I'm not that lucky so I'm not going to try, and the vehicle I wanted to use it in I no longer own.
   / Kubota 10W30 oil, synthetic or dino? #26
I will not be purchasing T6 I will be purchasing
Valvoline because the specs approx the same and
its $20 less than T6 at TSC and with the temps
in the 90's & 100"s 5W40 works for me
I can remember back in the 60's I wanted 10W30
and they put straight 20W in the back I didn't check
and when I went to change oil I had already drained
and filter off so added the 20W big mistake the next
morning the temp was -10 degrees and it wouldn't
even grunt! Our car calls for 10W20 but I do believe I will be using 10W30 pure synthetic
willy
   / Kubota 10W30 oil, synthetic or dino? #27
Got 0w30 M1 certified European diesel rated in both the B2601 and Isuzu generator.
   / Kubota 10W30 oil, synthetic or dino? #28
Menards drops the 11% every year. They change over from the 11% to holiday sales. That period is Christmas, New Years, President's Day, Valentine's Day, Easter. I think the 11% comes back in March.
   / Kubota 10W30 oil, synthetic or dino? #29
Maybe, maybe not. So far it's not. Don't really matter a lot. when you factor in sales tax, the 'rebate' drops tp 6% anyway.
   / Kubota 10W30 oil, synthetic or dino? #30
Still have that email? Can you post it please?
I ran t6 5w40 in a 09 accord that was burning 2qts every 1,000mi. I changed the oil about every 1,000mi and did that for about 7-10k. T6 actualy fixed the oil consumption issues I was having and have since changed to 5w30 and wont be 1qt low in 4,000mi. I have the same cat on the car they sold it with in 2009.
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
1996 INTERNATIONAL 4700 4X2 DUMP TRUCK (A51406)
1996 INTERNATIONAL...
2018 Ford F-150 (A53422)
2018 Ford F-150...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
2011 KENWORTH T800 KILL TRUCK & TRAILER (A53843)
2011 KENWORTH T800...
