HIITMan
Member
- Joined
 - Apr 30, 2023
- Messages
 - 41
- Tractor
 - Branson 2400H
I used my test light for all of the testing.  I connected it to the solenoid plug and turned the key on, one wire came on bright corresponding to the plunger going it, then went out after a few seconds.  Then connected it to the other wire, the test light came on dim for a second then went out.  The relays are all under the cowl under the instrument cluster.  I found one relay, unplugged it, turned the key on, the solenoid still had power to it.  I unplugged the other relay, the fuel shutoff solenoid  had no power.  I tested the plug that goes into the one relay, it has power and does not lose it when the key is turned on.  I moved one  relay to the other relay plug, no change to the fuel shut off solenoid.  I removed the plug to the OPC controller, no power to the fuel shutoff solenoid.  I grounded the test light and then touched it to some of the wires on the Controller.  One of the wires caused the fuel shutoff solenoid to pull the plunger in and it stayed in,  I tried other wires, found one that kicked the starter over.  So I put the shutoff solenoid back in and touched the test light to the wire and the plunger went in and stayed in. I touched the test light to the wire for the starter, the tractor started up and stayed running.  I plugged the plug back into the Controller, the tractor shutdown.  I don't know what I found out.  Is it the Controller that is bad or is it the ignition switch.  Doesn't seem like to me it's the other relay.  Any ideas?
