General thoughts on the 2515h?
   / General thoughts on the 2515h?
I dont think 21hp is going to run a 6 ft bushhog; but I might be wrong. 5 ft bush hog and 6 ft finish mower probably.
While terrain and use can change up the equation you are, overall, right on point.
   / General thoughts on the 2515h? #12
This is my second Branson. I called the dealer that I bought my first tractor from and they were awesome. The dealer submitted a warranty claim on the curl hydraulics and was able to get a new pair no charge and I was out of warranty a few months, loader is only covered for 1 year. I had to replace the hydraulics myself as labor was not available unless I pay out of pocket. A few months later my lift hydraulics started leaking. I am going to replace the lift hydraulics this fall. This tractor will run a 5 ft bush hog and finish mower, just plan on going super slow. I hear the shuttle guys do better since they are direct drive.
   / General thoughts on the 2515h? #13
I see bent hydraulics all over on the branson Facebook page. It's a common problem across many brands these days....cheap metal.
   / General thoughts on the 2515h? #14
Are the owners saying they stayed within the published loader lifting capacity, but the hydraulics bent anyway?
   / General thoughts on the 2515h? #15
I was well within mine. Not sure about everyone else. Seems to happen more when the pistons are fully extended which makes sense as that is when they are their weakest.
2020 Kinze 3505 High Speed 6/11 Planter (A56438)
2020 Kinze 3505...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2020 FREIGHTLINER...
2010 Case 580N (A60462)
2010 Case 580N...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
