Case IH 2290 hydraulic hose connected to the hydraulic pump
   / Case IH 2290 hydraulic hose connected to the hydraulic pump #1
iviper
case 2290
trying to fix my case 2290's hydraulic leak
ive identified the leak to the hose that runs from the hydraulic pump to the main controls in the cab, i cant for the life of me figure out how to remove the hose, it spins freely but doesnt unscrew, and its not a push pull release
refrence pictures : Case IH 2290 - CASE DIESEL TRACTOR(01/78 - 12/83) Parts Diagrams
pictorial index (00)
1-016 brake hydraulics
#11 is the hose i need to replace
   / Case IH 2290 hydraulic hose connected to the hydraulic pump #2
If it's the hose in your photo, it's not mean to come apart. You replace hose, line,and all as a unit.
including the hydraulic pump? if not where could i find a replacent?
   / Case IH 2290 hydraulic hose connected to the hydraulic pump #4
No, not the pump. The line will separate on the end of the steel portion.
   / Case IH 2290 hydraulic hose connected to the hydraulic pump #5
it’s been to many years to remember exactly which ones but some of those lines you have to lift the cab to get them out. It’s a long days work. The maintenance book tells you which ones.
how would i get it off the hose thats connected to the hydraulic pump, spins free but doesnt unscrew
   / Case IH 2290 hydraulic hose connected to the hydraulic pump #7
This really doesn't make sense. I could see the hose turning but if the nut turns counterclockwise it has to unscrew. Do you have a wrench on the nut?
   / Case IH 2290 hydraulic hose connected to the hydraulic pump #8
Are you able to provide us with some more pictures where the hose enters the pump?
2013 CATERPILLAR D6T LGP DOZER (A51406)
2013 CATERPILLAR...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2016 Nissan Frontier Ext. Cab Pick-up (A53422)
2016 Nissan...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
