Why so much tongue weight on 22' car hauler trailers?
   / Why so much tongue weight on 22' car hauler trailers? #41
If those trucks had headlights like a newer Tesla they could take a minute and lower them on the touch screen using the headlight settings. Or if the US would catch up with EU they would automatically adjust (adaptive headlights) and cut the light going into the oncoming drivers eyes without having to do anything since it is already equipped.
A lot of cars and trucks have a dial on the dash that you can use to lower the headlights. Most of the ones I've owned for the last 15 years have had them. And we do have automatically adjusting (up and down) headlights here. My wife's 2008 model VW has them so its not just on expensive cars.
   / Why so much tongue weight on 22' car hauler trailers? #42
I'm in the market for a 22' car hauler for my Kubota. What I've been noticing is that most of the trailer length is in front of the axles, putting a lot of weight on the hitch. What am I missing here? My last 22' trailer had the same problem and I recently sold it. I was constantly being flashed at night for high pointing headlights. Any manufacturers that put their axles a little more towards the front?
Placement of load, obviously weight needs to be on trailer tires, hard to get one trailer to fit all vehicle lengths - sometimes placement requires backing on trailer - equipment / buckets up front seem to balance a little easier, if you are new get a weight scale hitch, or simply use a scale and experiment, placement of load and following GVW guidelines work - overloading the hitch is not a good idea, it not only can cause serious handling problems it can easily fail under hard braking / maneuvering
   / Why so much tongue weight on 22' car hauler trailers? #43
The Tesla Cybertruck also has adaptive self leveling air suspension. So, squatting on the rear end should not be an issue. Also, the extra weight of the vehicle should make towing nice (as long as one isn't towing across the country).
The RAM 1500 Limited has had air suspension for quite some time, but at a premium price. Apparently it is now a factory add-on option for most other RAM 1500 pickups.
I rented a Chevy 1500 about 2 years ago and towed my trailer with it briefly. I was impressed that it didn't sag.
   / Why so much tongue weight on 22' car hauler trailers? #44
Yeah but the newest headlight system (adaptive) can do much more than just raise and lower the beam. They control individual high output LEDs. The matrix lights on my Model Y can actually spell words with the lights and that is different than just raising or lowering the entire beam. It allows selective dimming in the light pattern, but as I posted before the law does not allow the system to be active in the US.
   / Why so much tongue weight on 22' car hauler trailers? #45
It seems that you have the wrong truck, not the wrong trailer. You may need to go up to a heavier duty truck to alleviate your problem. Good tongue weight is essential, or your trailer will be unmanageable and will be steering your truck. If you have the room. you may be able to move the tractor back a little on the trailer to shift some of the weight off the tongue. Also, if the trailer is not level and tips down at the hitch, more weight shifts to the tongue.
   / Why so much tongue weight on 22' car hauler trailers? #46
The axle location is based on having optimum control of the trailer while towing. When the axle is moved too far forward you stand a better chance of losing control of the trailer. With the amount of weight you can have on the trailer it would take control of your vehicle and cause an accident that would cause injury or death to yourself and or others.
   / Why so much tongue weight on 22' car hauler trailers? #47
We used to joke that the way to increase the load capacity on a dump truck was to cut the mud flaps shorter so they wouldn't drag. Seems like changing the headlight angle due to an overload makes about the same amount of sense.
   / Why so much tongue weight on 22' car hauler trailers? #48
The link to etrailer, which explains the 60/40 and 10%-15% is spot on. With that said, if you have a trailer that has the axles farther back, you need to keep in mind the purpose of that trailer. It isn't going to be an all-purpose trailer, it's a purpose-built trailer. A car hauler is purpose-built to haul a car, not a tractor. Not saying you can't haul a tractor on it. Just saying that you need to keep in mind that the trailer was "purpose-built" to haul a car. A car is usually balanced at 60-40, or 55-45. And when you load a car, generally speaking it's going to only be slightly forward of the the center of the axles, and not hanging off the back. A tractor is usually (especially with a FEL) front heavy, and with the loader it's hard to not have too much tongue weight because the loader will be all the way to the front of the trailer, and the rear tires at the rear of the trailer. So, either the trailer is meant to have a car that is easier to position as it was intended, or it's meant to be pulled by a 3/4 ton or one ton. Or, as mentioned, a weight-distribution hitch NEEDS to be used.
Loading a trailer is very often done wrong. How many trailer do you see with just a few things on it, but all of the load is at the front? I see it all the time. Motorcycles loaded on the front of a 16 foot trailer. Why? Because they want to use the front of the frame to hold the front tire. The proper thing would be to install wheel chocks on the trailer so the bike could be loaded over the axles (slightly forward) to keep the balance at 60/40 and the tongue weight at 10%-15%. If said bike is loaded on the front, but towed by a 3/4 ton truck, no big deal. But if towed by a 1/2 ton, or SUV, the bike needs to be only slightly forward of the axles. Another thing to keep in mind. I have two trucks. Both Rams. One is a 1/5 ton, the other is a Dually. However, they BOTH have the exact same hitch. Rated at 5,000 lbs, or 10,000 lbs with a weight distribution hitch. Long story short here....If you are pulling that trailer with a tractor on it, with a 1/2 ton truck, you NEED to load it right, AND use a weight-distribution hitch.
   / Why so much tongue weight on 22' car hauler trailers? #49
if you are pulling with a 1/2 ton truck you may need to use a weight distribution hitch. That can help a lot if your truck is not level. I WOULD NEVER want to buy a heavy trailer with axles in the center. It is important that the trailer trail well BOTH empty and loaded. This is my 20' tilt bed which is 20 foot. I use a WD hitch and it trails perfect. Moving axles forward - increasing weight on the back may create the most dangerous problem with sway control. Most good WD hitches also have sway control. The books say 10-15% of gross trailer weight on the tongue. I use 10%. This trailer is 14K. What is the weight of the trailer you want this time and what is the max weight of what you want to tow? When you get your new trailer, load it and go to a CAT scale to verify all the axles weight to find the best way to load it for trailing and safety. BUY a good trailer. But they are very expensive now. Best Wishes. Consider all the options you may need. BRAKES on all axles, Heavy set back front jack with side crank, location of spare, led lighting, ramps or tilt etc.
EDIT: I should also add - Keep all your numbers in vehicle specifications - Max combined Vehicle -GRVW - max vehicle axle weight, max trailer weight (load including weight of trailer) and Vehicle max tow weight. You may not be able to keep all the numbers in spec. If not, either trailer it too big or tow vehicle is too small. I have a 33 gal fuel tank. When it is full, I am very close to vehicle gross rated weight.
What brand and model is that trailer?
   / Why so much tongue weight on 22' car hauler trailers? #50
I found a great book on trailers at the thrift store about 6-months before mu buddy and I rebuilt his trailer. Which was a home built by a local Welder.
This is the book:
Trailers : How to Design and Build. Volume 2. Structure, by M. M. Smith. It can be found on Amazon, along with the other two books in the series..​
I highly recommend the series of books, the third book on how to evaluate and buy trailers is probably the best if you don’t intend to build a trailer. There are a bunch of bad reviews, from what appear to be welders who were expecting plans, and disappointed..
The fact that you can weld does not mean you can design and build a trailer. I helped a buddy, rebuild a home built equipment trailer, he bought off a local mason.
When we got the deck stripped off, I used the second book in the series to help me analyze, the frame. (I’m an engineer, and could have figured it all out myself. But having a primer from someone with years of experience designing trailers was a big help, and saved hours of research.). The frame was way oversized, and could handle a 12,000-lb load, but only had 3,500-lb axles and springs. We replaced the old axles and springs with new 4,500-lb springs with electric brakes. In the process, we moved the axles back from the center of the deck, and located the front spring eye, at the center of the load deck. The trailer towed a lot better with the axles moved back. Now that I own the trailer, and have towed a few different things with it, I would move the axles back about another 16-inches. Just becasue ,as others have said, you want at least ten percent of the load on the tongue, and with the FEL on and the bucket all the way forward, I‘m barely there.
2012 John Deere 7280R MFWD Tractor (A53472)
2012 John Deere...
2021 CATERPILLAR 420 XE BACKHOE (A51246)
2021 CATERPILLAR...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
INOP/NON-RUNNING 1999 International F-2574 Fuel Lube Truck, VIN # 1HTGGATT4XH682675 (A51572)
INOP/NON-RUNNING...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
