Adding remote hydraulics to my Ford 4610LCG to run a batwing mower.
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #1
Kptryn
Ford 4610LCG
Hello. Looking for advice on what to buy to add remote hydraulics to the rear of my Ford 4610LCG to lift/lower the decks on a batwing mower. Needs to have a float position. Thank you in advance!
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #2
Welcome to TBN!
Do you only have one hydaulic pump on your tractor? Have you already looked at the kits online?
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #3
Reliable Aftermarket Parts sells kit for this. I have used them for other things, but not this. My tractors came with them. Mounts under the seat, like Ford does.
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #4
Do these kits have a float position?
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #6
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #7
Are you sure it needs a float function? Most batwings need a single-acting valve.
Or you can use a directional valve with float, but you'll need to route the unused valve port back to the tank to avoid dead-heading your pump.
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #8
Batwings don't need float. At least not the 100 or so different ones that I've hooked up. Most of them only have a one way hydraulic cylinder to raise the deck and gravity down.
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #9
Correction on my post 7. A valve with a float detent should work with one connection.
Thanks for all the info!!
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A58214)
2013 XLR...
X-CEL GOOSENECK TRAILER (A54756)
X-CEL GOOSENECK...
AMQ45 Hydraulic Quick Connect (New/Unused) To fit CAT345 (A59225)
AMQ45 Hydraulic...
2025 SDLANCH Wood Chipper (A55974)
2025 SDLANCH Wood...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
