Adding remote hydraulics to my Ford 4610LCG to run a batwing mower.
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #1
Kptryn
Ford 4610LCG
Hello. Looking for advice on what to buy to add remote hydraulics to the rear of my Ford 4610LCG to lift/lower the decks on a batwing mower. Needs to have a float position. Thank you in advance!
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #2
Welcome to TBN!
Do you only have one hydaulic pump on your tractor? Have you already looked at the kits online?
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #3
Reliable Aftermarket Parts sells kit for this. I have used them for other things, but not this. My tractors came with them. Mounts under the seat, like Ford does.
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #4
Do these kits have a float position?
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #6
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #7
Are you sure it needs a float function? Most batwings need a single-acting valve.
Or you can use a directional valve with float, but you'll need to route the unused valve port back to the tank to avoid dead-heading your pump.
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #8
Batwings don't need float. At least not the 100 or so different ones that I've hooked up. Most of them only have a one way hydraulic cylinder to raise the deck and gravity down.
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #9
Correction on my post 7. A valve with a float detent should work with one connection.
Thanks for all the info!!
JOHN DEERE 400 - 4R ROTARY HOE (A52708)
JOHN DEERE 400 -...
CAST IRON POT (A58374)
1969 MERCURY MOTOR AND STAND (A58374)
1969 MERCURY MOTOR...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2016 FREIGHTLINER...
2011 GALYEAN 130 BBL VACUUM TRAILER (A58214)
2011 GALYEAN 130...
TAKEUCHI TL12V2 SKID STEER (A52708)
TAKEUCHI TL12V2...
