Adding remote hydraulics to my Ford 4610LCG to run a batwing mower.
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #1
Kptryn
Ford 4610LCG
Hello. Looking for advice on what to buy to add remote hydraulics to the rear of my Ford 4610LCG to lift/lower the decks on a batwing mower. Needs to have a float position. Thank you in advance!
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #2
Welcome to TBN!
Do you only have one hydaulic pump on your tractor? Have you already looked at the kits online?
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #3
Reliable Aftermarket Parts sells kit for this. I have used them for other things, but not this. My tractors came with them. Mounts under the seat, like Ford does.
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #4
Do these kits have a float position?
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #6
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #7
Are you sure it needs a float function? Most batwings need a single-acting valve.
Or you can use a directional valve with float, but you'll need to route the unused valve port back to the tank to avoid dead-heading your pump.
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #8
Batwings don't need float. At least not the 100 or so different ones that I've hooked up. Most of them only have a one way hydraulic cylinder to raise the deck and gravity down.
   / Adding remote hydraulics to my Ford 4610LCG to run a batwing mower. #9
Correction on my post 7. A valve with a float detent should work with one connection.
Thanks for all the info!!
WINCH CABLE DRUM (A58216)
WINCH CABLE DRUM...
Year: 2005 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2005 Make...
2016 Ford F-450 Utility Flatbed Truck (A56858)
2016 Ford F-450...
2016 Volkswagen Jetta Sedan (A56859)
2016 Volkswagen...
2019 Freightliner M2 106 Water Truck (A56858)
2019 Freightliner...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56859)
Pace American...
