Ford 3000 3 pt. lift arms wait and wait to lift after sitting
   / Ford 3000 3 pt. lift arms wait and wait to lift after sitting
Wouldn’t the shaft seal if it were bad at the flywheel end fill the engine with hydraulic oil?
   / Ford 3000 3 pt. lift arms wait and wait to lift after sitting #12
It could. I’m not that technical. The seal will look perfect, wore or degraded just enough for oil not to seal it as it should. And the shaft may be scored instead. Never know until you investigate my friend. I like the way you think, good luck sir
I am going to order a pump rebuild kit.
The premium kit with wobble shaft, plate, pistons and seals.
   / Ford 3000 3 pt. lift arms wait and wait to lift after sitting #15
That’s the way. You can keep those pistons and springs till you need them. From what you said, the pump is fine after it’s primed. Good indicator that end is fine. But you never know and I’m just trying to help. Check everything in that circuit while you are there. O rings if involved. That thing has got to be exactly right to work
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
2025 LandHero Universal Bucket Pins (A49462)
2025 LandHero...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52128)
REYNOLDS 100 - 8...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
