Ford 3000 3 pt. lift arms wait and wait to lift after sitting
   / Ford 3000 3 pt. lift arms wait and wait to lift after sitting
Wouldn’t the shaft seal if it were bad at the flywheel end fill the engine with hydraulic oil?
   / Ford 3000 3 pt. lift arms wait and wait to lift after sitting #12
It could. I’m not that technical. The seal will look perfect, wore or degraded just enough for oil not to seal it as it should. And the shaft may be scored instead. Never know until you investigate my friend. I like the way you think, good luck sir
I am going to order a pump rebuild kit.
The premium kit with wobble shaft, plate, pistons and seals.
   / Ford 3000 3 pt. lift arms wait and wait to lift after sitting #15
That’s the way. You can keep those pistons and springs till you need them. From what you said, the pump is fine after it’s primed. Good indicator that end is fine. But you never know and I’m just trying to help. Check everything in that circuit while you are there. O rings if involved. That thing has got to be exactly right to work
2006 Kobelco SK210LC Hydraulic Excavator (A49461)
2006 Kobelco...
2019 KENWORTH T680 SLEEPER (A51222)
2019 KENWORTH T680...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2017 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2017 CATERPILLAR...
