What did you do with your Chinese baby digger today?
   / What did you do with your Chinese baby digger today? #541
cant afford to put a bigger one in it right now BUT still eying one of my Kohler 20's out of an old sunstar. I know that would run it!
You don't want a bigger engine, esp a twin. No room. The thumpers have plenty of power, and are quite inexpensive.
   / What did you do with your Chinese baby digger today? #542
dug sweet taters with mine today. Ground is as hard as concrete and fork was out!
  • Good Post
Reactions: 1hp
   / What did you do with your Chinese baby digger today? #543
Was doing some clean up from stump removal with my Typhon this last week when I had a track jump the sprocket. First time needing to put it back. I learned a few things in the process. First thing I learned is the large track tension lock nut is a size that I do not have (32mm) I also learned that it was not easily reachable with an adjustable wrench due to the access area for it.
Manged to still loosen the tension bolt (16mm) and reinstall the track but not really able to tighten the lock nut. I ordered this wrench from Amazon and it is just the deal for this. Thought I would pass it along.
   / What did you do with your Chinese baby digger today? #544
If anything happened to my 13.5hp Brigs, I think I would settle for a 10-12hp Oil Burning Thumper.
   / What did you do with your Chinese baby digger today? #545
I hope you can find that wrench when you need it, but it looks like the right tool. I used a 1.25" box-end wrench on mine, but I have not needed it in years.
   / What did you do with your Chinese baby digger today? #546
It is now in a tool box dedicated for the excavator mounted to the little trailer I move the excavator around with. I like to know I have the tools available instead of having to run back to my shop. :)
   / What did you do with your Chinese baby digger today? #547
I put my "tools box" behind the seat - has most everything I need to fix in it - added a bracket and adhesive foam so it sits tight.
   / What did you do with your Chinese baby digger today? #548
diggin in the tile line still. right track keeps coming off. Been doing that since I got it new last year. front wheel is junk,---wobbles bad.
Might just have to drag the digger around with a tractor til I get this job done. No time right now to screw with it. I bought the thing to use and NOT have to reman it!!!!
   / What did you do with your Chinese baby digger today? #549
When I removed one of my idler wheels, I never took it apart to see what kind of bearing it uses. Since it is not greaseable, I hope it is one or 2 ball bearings, which should be cheap to replace.
If you remove 2 socket head bolts, you should be able to remove the side plate and see. It seems to me that replacing that bearing will be less work than one track remounting effort. If you do this, please post pix.
  • Good Post
Reactions: 1hp
   / What did you do with your Chinese baby digger today? #550
I figure its just a bolt thru a bare bushing in there, --- have no idea yet but might try to take a quick look ! Track still off since I was mowing waterways yesterday and didnt have time to work on tile line.
New machine with 24 hours should NOT have tracks jumping off! Only the right side comes off left side is fine.
still gotta modify the bucket to make it cut,---been grinding the **** out of the edges and it does a LOT better but still needs more!
Pulls way too hard and kills the motor even wide open!
Later on I will make my own bucket that will work but for now stuck with this one.
Also 2 days ago the hour meter went dead on it! I look at it every time I start up and it wasnt on that time. Been working up til then. Any ideas on whats up with that? or a fix?
I will take pix of the front when I get it off too and see for sure whats in there. Raining today, so maybe I can work on it since I cant mow.
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2015 KUBOTA M5660SU 4X4 FARM TRACTOR (A51243)
2015 KUBOTA...
1261 (A50490)
1261 (A50490)
Landoll (A50657)
Landoll (A50657)
2005 Sterling Acterra Tender Truck (A52128)
2005 Sterling...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
