N H Ford 445C TCM no. FONN7Z319AAR.
   / N H Ford 445C TCM no. FONN7Z319AAR. #121
What fluids are you concerned about? I've picked Shell Rotella T6 for engine oil, Shell ELC for coolant, and my hydraulic fluid, trans, rear diff and front axle fluids (all the same spec'd fluid on these) are due for a full flush/change in the spring but I haven't decided what to use yet. I've added a little of the VP J20 fluid just to top up. I've read lots of different thoughts on this, some people say that the wrong fluid will cause clutch and brake damage. I would be interested to hear what @TractorTech thoughts are on the subject.
As a side note, I've dropped my PWM setting for the FWD & REV solenoids (setting #1) to 85% also, just to keep things near 12V - since that wasn't spec'd in the manual as "full battery voltage" like the lockup solenoid. It doesn't seem to have made any kind of difference in terms of actual operation as far as I can tell. I just ran my machine for about 4 hours over the last week clearing snow and building the kids a small sledding hill, everything working great.
One of these days I may pull the fuel tank and actually have a look at the solenoid coils to see if I can pull a mfr's part number. Would be interesting to see if I can find an actual rated voltage.
   / N H Ford 445C TCM no. FONN7Z319AAR. #122
First, the hydraulic oil should be a high quality trans/hydraulic fluid. New Holland's MultiGrade 134™ Hydraulic Transmission Oil is what is called for and equivalent oils will list the 134D spec on their label. I personally use Mobil Delvac or 424, but Shell, Kubota UDT and other notable fluids will work well.
In the front axle and hubs, you can also use 80w90 in warmer climates to reduce leakage. @fred saas, I added a chart for capacities on your 445C
Something to note on Tractor Loaders with FWD, make sure you grease the rear pivot bushing as it contains a thin oring that contains the oil in the front axle. Lose oil, lock up reversing gearbox and $$$$$$.
TLBs do not have this reversing box.
Lastly, the coils are 12v. The replacement coil that is sold on Amazon and other places is shown here:
   / N H Ford 445C TCM no. FONN7Z319AAR. #123
That's a nominal rating on the solenoid label, too bad there's no data sheet. And intermittent duty doesn't seem correct, these coils should be continuous duty rated... Intermittent duty solenoids are for something like a starter where they're only used for a short period, then allowed to cool.
I've seen lots of argument back and forth on message boards about the trans oils. Some guys say the label needs to specifically say "meets or exceeds 134D" or whatever rating, not just show it on the label. Then some say they used an oil that didn't say "meets or exceeds" and it ruined their clutches or brakes, or made them shudder. Hard to know what to believe, reading some of these message boards. I should like to think that any oil that mentions the required spec on the label should be good. Perhaps those guys just had a bad run of luck with their machine.
The problem was that the 'Speed' on the controller (display) was set to 0%. Once it was set to 60% - off she went!
eKretz and I both settled at 85%. Dead slow when I remove my foot from the pedal. A soft clunk in a couple seconds. give it rpms and off you go. Again, foot on clutch pedal, dead slow, shift, take foot off pedal, couple of seconds, soft clunk, then rpms. I hope I made some sense.
Boy oh boy, I never thought this tractor would be so time consuming, but I guess nothing good comes without some adversity.
   / N H Ford 445C TCM no. FONN7Z319AAR. #126
Yeah, a bit, I suppose. But it's worth it to get a good machine in the end.
   / N H Ford 445C TCM no. FONN7Z319AAR. #127
Ok, here is the pinout and connection guide for my 555D using 2 controllers, one for forward and one for reverse. The controllers are "Hanlei CCM-TK." This will allow the machine to function just as it originally did with the shuttle lever. Merry Christmas! Be sure to check your individual machine's schematic to be sure your wires are the same before using these colors! I attached photos of the controller terminals so you can see the labeling of the terminals as well as the two plugs that I sourced from the original TCM. Follow the connections in the 2nd image with the text, ignore the connections in the controller terminal image - that is currently set up for my temporary drive method that uses the toggle switch rather than 2 individual controllers. All of the original safety interlocks should still function with this setup if they were active and not previously disabled, as the power for both the brown and gray wires (FWD and REV signals) comes off of the red wire, which gets shut off if any of the interlock contacts are broken in the electrical path. If any of those were previously disabled, they will still be disabled.
eKretz do you think this would work the same on a Ford 445C tractor? I think my module is the problem with mine. Can you tell me what this is and if I can replace with something like an inline fuse. I have some that I can’t take apart like this one. It may be bad
   / N H Ford 445C TCM no. FONN7Z319AAR. #128
I believe the controller is the same. The item in your picture looks like a diode. You should be able to easily test it with a multimeter that has a "diode test" function. Most modern digital meters have that. It should conduct and display voltage drop in one direction, and "OL" in the other. (Swap leads/terminals to test opposite directions).
   / N H Ford 445C TCM no. FONN7Z319AAR. #129
The only panel on my machine that needs to come off is the flat panel under the steering wheel up under which the module was bolted in. And yes Fred, the red wire is extraneous in this application. You can just leave it taped or capped with heat shrink.
On that note, I finally received my correct order and got the other controllers I ordered. I made up a small extension harness tonight and tested the controllers, everything is working perfectly via shuttle switch. I used the same color wires on my harness that the original harness uses. I'll include a photo of the wired connections. I just ran a jumper across from "Power -" on one controller and connected it to the same terminal on the other with a black wire. On the overload setting I set it at 3.0 amps, and I think I'm settled on a 3.0 second soft start. I left the under-voltage protection setting at 10.0 V. I left my displays set for amperage so I can monitor the current the solenoid coils are pulling. Oh, and the "soft stop" timer I set to 0.2 second so that it's almost instant off.
Im gonna receive the controllers in the next couple of days and make an extension harness like yours. Where in the tractor did you screw your boxes?
   / N H Ford 445C TCM no. FONN7Z319AAR. #130
I just kind of temporarily put mine up under the dash above where the pedals are. Only one bolt in each to hold them there, in already existing holes. I haven't gotten around to a more permanent mounting yet.
   / N H Ford 445C TCM no. FONN7Z319AAR. #131
My turn. Buddy says hi.
   / N H Ford 445C TCM no. FONN7Z319AAR. #132
My 545D with lockup is exactly like yours.
   / N H Ford 445C TCM no. FONN7Z319AAR. #133
8x8s should all be the same.
Nice to have a workaround
   / N H Ford 445C TCM no. FONN7Z319AAR. #134
Hello guys. So, finally I'm doing the bench test before transfer to the tractor 🚜.
In the setting #1 I just increase the value one point, everything else is at default.
This is correct?
   / N H Ford 445C TCM no. FONN7Z319AAR. #135
fred saas this company repairs tcm's
fred saas this company has many many parts if you ever need
anything else:
willy
   / N H Ford 445C TCM no. FONN7Z319AAR. #136
This is correct?
Controllers get 12.5 solid when engine running. I disconnect black wire 'cause when running and switch on wire get 2v.
Tractor engage momentary then nada.
I'm still on the fight
   / N H Ford 445C TCM no. FONN7Z319AAR. #138
POWER WATTAGE MOTOR NEED TO BE SET TO 60. MY TRACTOR ITS ALIVE! THANKS TO YOU @eKretz @TractorTech
👍 Good deal! Happy to help. Sorry about the lack of response up to now, I didn't get any notifications for these latest posts, just happened to check in and see them just now!
   / N H Ford 445C TCM no. FONN7Z319AAR. #139
Thanks to @eKretz for coming up with a simple, inexpensive solution to save an otherwise dead tractor.
2364 (A60432)
2364 (A60432)
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A59231)
2009 Mariah SC23...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2018 CATERPILLAR...
