1961 Ford 4030 - Clutch Problem?
   / 1961 Ford 4030 - Clutch Problem? #41
I think you're right - I have attached a photo. Is this the reverser?[/QUOTE
yes that is the aux. trans but it could be a reverser a stepdown trans or a step down and up trans but move that lever and see what happens
   / 1961 Ford 4030 - Clutch Problem? #43
yep.. and I knew it would be a 4spd one we startedtalking aux trans...
starting to make sense now.. :)
   / 1961 Ford 4030 - Clutch Problem? #44
here's a lil sherman dealer pic..
This morning I confirmed that it is a reverser. It was engaged, but in reverse. When I switched it, the PTO turned clockwise as expected, and the tractor lurched forward a tiny bit, instead of backwards as before. With the tires on the ground, the PTO works when the clutch is engaged - in both directions.
Will the PTO clutch engage even if the main clutch is slipping?
Not to get off topic, but my tractor has a 730 Loader. I assume I will have to remove that to split the tractor?
   / 1961 Ford 4030 - Clutch Problem? #46
if it won't drive(move) but pto spins, then the front of the tranny is getting power .. and at least thru to the counter shaft probably...
I'd next suspect a broken pinion coupler tube, pinion gear, or sheared rivitrs in teh ring gear, or a broken axle.
pretty much in that order.
soundguy
Doesn't the fact that when I jacked up the rear end and spun a tire, the other tire spun the opposite way, rule out an axle problem?
Also, when I had it jacked up, the tranny went through the gears with no problems, and the wheels turned.
With a double clutch, can one disc be toast while the other is ok? Would that account for the PTO working properly?
I really appreciate all this great advice. I've learned to ask the experienced folks before taking things apart.
   / 1961 Ford 4030 - Clutch Problem? #49
you have a 4spd trans and a pre tranny.. you cannot have a dual clutch.
the reason it may work jacked up is because there is no load. a broke axle can grab at the break site and still turn under no load.
if pto works and wheels won't move.. input is getting power...
If I have a broken axle, shouldn't I be able to hear the differential turning? I hear nothing wrong when I engage the clutch, and the wheels move just a tiny bit. Also, is my differential similar to an automotive one? Are there two half-shafts? Wouldn't one turn even if the other was broken?
I received my shop manual yesterday, so I'm ready to get to work. Thanks again for all the help.
International 720 6-Bottom Plow (A52128)
International 720...
2020 Hitachi ZX60USB-5N (A47384)
2020 Hitachi...
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
