2.7 ecoboost opinions
   / 2.7 ecoboost opinions #41
There are a couple things that aggravate me about the 19F150 that I have. One is the auto shut off for the engine. When you come to a. Stop, the motor. Shuts off until you step on the gas again. I disabled it by unplugging a small white plug in thing under the dash, but have to reconnect it if I'm towing something otherwise the trailer breaks won't work. Not a big deal ..just a nuisance. The other thing that is really annoying is the auto locks for the doors and tailgate. As soon as you start rolling, they all lock. I can't count how many times I have gotten out of the truck and gone to the tailgate to get in the bed..only to have it locked and have to go back to the door and hit unlock... Friggin ridiculous ...and ford says it can't be disabled at the dealership. ..I call BS
You need to explore this application which can tweak many firmware options to your liking: FORScan Home
   / 2.7 ecoboost opinions #42
Running empty , great mileage. Pulling a trailer, mileage drops considerably. Still has lots of go power, but you have to feed it. My favorite argument with the small, high hp engine crowd was always " If small engines are so great, why don't they put them in big trucks?" Have a 2018 150 Eco 2.7.
Relatively speaking they do. The biggest semitruck engine is 15L, about 5 times the 2.7L, and much heavier truck than 5x the F-150.
   / 2.7 ecoboost opinions #43
I believe the ecoboost engines require premium fuel when towing....check the manual.
I have read that multiple places but have yet to fill up with premium fuel. The main reason is I have a 36 gallon tank and adding premium to what is in the tank will dilute it down and show no improvements and to fill up with premium fuel would be rather costly. I tow frequently but mostly shorter trips.
   / 2.7 ecoboost opinions #44
Someone did a test and found the Ecoboost engines were one of the few that actually can benefit from premium gas. The engine tuning program seems to have enough range to gain a bit of horsepower and torque with higher octane. That said, I have a 2017 3.5 and have never run premium gas. Even towing I've never seen the need for that last 10 hp.
Relative to the truck computer settings, each year seems to be different. On my 2017, you can turn the autostop/start off in the setup menu, as well as the automatic door locking. However, I can't find a way to adjust the MPG calculation, which is consistently 0.5 to 1.0 mpg optimistic.
Better pic from today. Sits a little low in the front. May install leveling kit. IMG_8559.JPG
   / 2.7 ecoboost opinions #47
My father has a 3.5L and it is impressive. He purchased a brand new GMC 2500HD with a 6.0L and his F-150 will out pull it every time. He loves his GMC, and still drives it around a bit, but the F-150 gets most of the daily driving and all tow duties. It gets great mileage and tows well.
He also added Airlift bags to the rear of his, which work wonders when wanting to level up heavy loads.
   / 2.7 ecoboost opinions #48
yes but diesel with lots of foot lbs of torque at low RPM
   / 2.7 ecoboost opinions #49
There is also the issue of duty cycle. If you look at a semi, it is expected to operating at heavy loads most of the time. Although the 1/2 ton trucks have great capability, most will not be towing heavy a large portion of the time. I think if you told Ford you expected to be towing 10K constantly, they would tell you to get a 250/350 diesel instead of a 150 Ecoboost.
   / 2.7 ecoboost opinions #50
There is a way to adjust the computer to be more accurate on your mpg. I read about it on an F150 Forum.
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
2015 INTERNATIONAL FLATBED (A58214)
2015 INTERNATIONAL...
