2305 FEL Float problem
/ 2305 FEL Float problem #1
raykos
Central Pa.
JD2305
Hi all,
I'm having a problem figuring out how to get my FEL into and out of the float postition. I remember reading about how to in one of my manuals, but I'll be darn if I can find it again!? Whenever I first started using the FEL, it seemed like I couldn't get it to float, now when I lower the bucket and want to scrape backwards, it seems to immediately go into the float position even though I don't want it to? I guess I must be doing something wrong without knowing it? What is the correct way to get the FEL into and out of the float postition?
Thanks,
Ray
/ 2305 FEL Float problem #2
To get into the float mode, a quick-sharp push forward on the joystick to get past the float detent. The joystick should remain forward and not return to the center.
To remove, just pull the stick back a little...
If yous is going into float to easily, then there may be a small problem.
TRAILER (A66736)
TRAILER (A66736)
AIR HAMMER (A64553)
AIR HAMMER (A64553)
2006 Ford F-450 Crew Cab 9ft. Stakebody Flatbed Truck (A66736)
2006 Ford F-450...
2023 JCB 90Z-2 T4 Midi Excavator (A66734)
2023 JCB 90Z-2 T4...
2018 MAGNUS MINI VAC TRAILER (A67714)
2018 MAGNUS MINI...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
